I would use Core temp over cpu temp.
the CPU temp is the general, overall temp of your cpu, however the most important readings are your individual core temperatures.
You use the Core temp to determine the thermal limit, not the cpu temp
Also cpu temp is the temp measured on the mobo, whereas the core temp is measured by sensors inside it
