1 - 2 of 2 Posts
Hello there overclock community, I have been using speed fan to keep track of my internal temperattures for a while now and i can not figure out what some of the temps are. From my comparisons, Temp 1 is my cpu temp since it matches up with my msi command center cpu temp, Temp 2 im guessing is the vrm on the board and temp3 i am guessing that it would be the north bridge or south bridge. Currently with my pc running at idle, the readings are as follow.
Temp1:41c
Temp2:52c
Temp3:35c
I am currently running a MSI 970A G43 Plus military grade class 4 motherboard with a AMD FX-8350 at stock speed with cool n quiet and turbo disabled. If anyone knows anything and could help me that would be greatly appreciated.
Put a load on all the components with a stress test program but do that one after the other. The temperature that skyrockets when starting the test is the temperature of the stressed component.
1 - 2 of 2 Posts
