1 - 3 of 3 Posts
to find out i left it open and a ran a program that would put full load on the cpu and watch the temps,to see which would increase the most.
there is a fair bit of tweaks in speedfan if you are keen, once you find out which temp is the cpu go into config, click on the appropriate temp and you will have an option to show in tray, click on it and you are good to go.
1 - 3 of 3 Posts
