1 - 3 of 3 Posts
Why dosent my CPU use its lowest speed? For the speed stepping, I will only go down to 1Ghz but has a 800Mhz profile why don’t it use it?
Not to nit-pick, but it's called Cool'n'Quiet. Does the same thing execpt AMD calls it Cool'n'Quiet and Intel calls it Enhanced Speedstep. Have you OCed your system at all? C'n'Q works by dropping your multi so if you OCed your system via raising the fsb, then it would be the lowered multi times the multi, resulting in a higher speed.
1 - 3 of 3 Posts
