it could be nothing, sometimes I get sensors picking up 120°C temps, or they're negative...the remote sensors let you monitor remote temps, but you probably don't have anything hooked up to it, and it's just displaying some temp...or something
as for the fans, you may need to change the settings in Advanced, you might have it set to DC mode instead of PWM or manual mode and they'll go full speed without you being able to change them
