1 - 4 of 4 Posts
Originally Posted by kevin_tsoi2000
127C???????????????? What in the world is that monitoring???
Speedfan is only as good as the temp. censors and BIOS on your system so if your bios has a temp bug or a faulty censor then you'll get odd readings.
Try Everest Home and compare the readings.You may need to update your bios to fix a possible temp.bug.
I TeK things...
speedfan also goes bonkers if you are running another fan/fsb utility like MSI's Core Center....disable that and see what pops up....
1 - 4 of 4 Posts
