1 - 8 of 8 Posts
I was playing splinter cell, and there's one part where it shows a cutscene after you climb up a ladder. Each time, (I tried several times) it freezes for a few seconds, then the screen goes blank, and the monitor says "out of range." I have to manually cut the power, and the restart to get my monitor working. Is this a video card driver error, or is it a messed-up game?<br />
<br />
EDIT: now it just reboots completely...anyone know what's going on? I already tried reducing the resolution, and stuff like that.
Reactions: Andrewchamp
Starting to become a BOFH
Which SC? The first one, Pandora Tomorrow, or Chaos Theory?
The original.
You're playing at a reso supported by the monitor? (dumb ?)<br><br>
Have you updated the game to the latest patch?
Discussion Starter #5
Yes and no. I'll try downloading the patch now. I'll porst back to let you know if it worked.
I've heard of a couple stories where the game crashed because it wasn't patched. It did it on some systems and others not.
Discussion Starter #7
Nope still didn't work....always crashes on that cutscene.<br><br>
EDIT: Here's the windows error, if that tells anyone anything. \\<br><br>
C:\\WINDOWS\\Minidump\\Mini103106-01.dmp<br>
C:\\DOCUME~1\\PATRIC~1\\LOCALS~1\\Temp\\WER2.tmp.d ir00\\sysdata.xml<br><br>
Note: Patrick is my windows username. (Named after me, of course - nice to meet you, too.)
Discussion Starter #8
Please? Anyone?
1 - 8 of 8 Posts
