Small update
Pci-E riser ordered
Motherboard stand-offs ordered
Acrylic plate to mount the motherboard on is ordered
Paint for some of the car parts ordered
_______________________________________________________________________________________________________________________
And some pictures.
Added white highlights to the interior
A closer look
The dashboard and steering wheel
The amount of details in this kit is stunning
Hard too see, but inside coming along
Photos taken late at night, so the quality is not the best
Most of inside done.
The back of the car, where the engine should go. Probably where I mount the graphics card
This is cool, fully functional suspension
Info on the Aventador
Engine parts painted in a more glossy silver, then the standard grey
The silver is very fitting
Protection is important kids
This is where the engine should go. But instead, I'm planning to put my graphical engine there
As you see, I have not assembled the seating or actual engine, as I know these are in the way for the coming components.
The motherboard will be mounted on an acrylic plate in the "cockpit" of the car. The I/O-panel will face towards one of the doors, so you can reach the USB by opening the door.
In the back I plan to put the GPU which will be a tight fit, but I do believe it's possible. Some of the GPU might go all the way into the cockpit.
The PSU is the big problem. With extreme luck it might fit in the front compartment. But that's doubtful. If I cannout put it there, I will make a wooden "pedestal", which the car will be placed on. Inside the pedistal I will put the power supply. I will try to make the pedestal elegant and discreet. No ridiculous carbon fibre wraps or similar.
Pci-E riser ordered
And some pictures.
A closer look
