I do plan on painting it. But once I get the GPU in place, I was thinking of seeing if I could attach any of the models original engineparts to the graphics card, too make it look more integrated with the actual model.
As of right now, the motherboard is pretty much on the best way it can be. The 24-pin is going on the front, Pci-E going on the back so the riser can reach it.Originally Posted by Richie123
Just a suggestion for you, for the mobo, would it be better mounted 90 degree anti clockwise to allow the wires to travel out the back? and as for the GPU mount, you could get a back plate, countersink some holes on the gfx card side so the screws are coming out the back, then put a couple of nuts on back of back plate to secure the bolts.. this way you will be able to put the holes exactly were you want them.
also spotted this if it gives you an idea![]()
I know yours is a lot more detailed, just thought you may not have seen it and it might give you some ideas..
Quote:Originally Posted by Andiders
So, the thought was too start sleeving, since I'm currently "innovatively dry" and don't know how to mount the graphics card yet.
So, I looked at the cables. Loves that they are all black like Corsairs PSUs are.
But then I meet problem 1.
These heatshrinks are like rock. You cannor simply do a cut, then pull them apart. Of course, it can be considered both good and bad that they are like that...
But lastly... Never encountered this before.
Most cables have these. They don't look like resistors, and I lack the knowledge to tell what they are, or how to sleeve over those in a good way. But MB-cable as well as GPU cable has them. I bet the CPU-cable do too.
Maybe you know what they are and how to do a good sleeve over them? Otherwise I need to either get an extension (which means tons of extra cable) or just imporvice and hope everything don't blow up. Any tips fellow Clockers?
I happen to be using the same PSU for my build. I called just EVGA and their tech support said "Do not cut them of the PSU will not work". Now, I'm not sure if he knew exactly what he was talking about, but cutting them off is not an issue? I assume you've done this before? I should also mention when I asked why they were there he didn't know...
Originally Posted by Kevin_CL
I happen to be using the same PSU for my build. I called just EVGA and their tech support said not to cut them of the PSU will not work. Now, I'm not sure if he knew exactly what he was talking about, but cutting them off is not an issue? I assume you've done this before? I should also mention when I asked why they were there he didn't know...[/quote
yes, i've sleeved quite a few of these psu's with caps and resisters on them. i believe they are there to maintain power efficiency maybe @WiSK can shed more light
Okay thanks for the info! + rep to you sir!Originally Posted by Kevin_CL
