Back home for a few hours.
I want to finish the extension cables for the titans.
I just finihed them but i had trouble with one of the pins\connectors.
I had to cut of the wires a second time. Grrrr. This time all went oke.
This cable is also finished. The next step is to cut a square out of the insertpanel to get a better curve "more away from the fans.
Now that i start cutting again i also make the grommet hole where the 24 pin extension is larger so all the cable from the right usb sockets and the usb port also com in line with the wires.
I am realy happy with the extension cables. It took me a while but the work payed off well.
Pictures !!!! A few.
To have the same distance as between the two titans i have to move the cable a bit inwards.
Ifi want to put in the usb-cable and the 2 right usb cables in line i have to make the grommet hole larger.
I am back tommorow morning.
