05-06-2017 "reservoirs back in the desk and mounted"
Measuring out the space that i have for redriling the holes for the reservoirs.
The reservoirs are back in the desk but i have to wait for the new led profiles before i put the 12mm tubing in.
In the meantime i am planning things ahead.
Wishlist;
- 2 GTX-1080Ti FE for changing out the Titans (moved 2 to my gaming rig downstairs);
- i want the new Asus screen for my desk;
- Intel 750 SSD pci-express 1,2TB
So the wishlist meaning i need a extra 4K for the desk to finish.
I think a long list.
in the mean time i did a quick job (he he finaly). I cut the 16mm tubing for the pedestel and put 1\4" tread in it. After reameasuring and recutting it the measurement is fine.
The parts fit. So tommorow i can finish the other pedestel.
I start tommorow with making a few acrylic o-ring\stopping rings for the 16mm tubing.
The 10 x 1000mm 16mm tubing is having the right thickness so the rings fit tide.
After i took the pictures i thought "yes need to paint that seiling part in the end of the pedestel also. So that is also a job for tommorow.
Crappy pictures but the are work pictures. The noce ones folow soon.
It is no PR having fingerprints and dust on the fittings but i get it all out for checking the 0-rings and cleaning tommorow.
Picture taken from the back of the desk. The botspower extension fittings making it easier to mount all.
O yes need to clean that up and paint it. /I use paint on a waterbase "quick dry and repaintable in 20 min".
Altho the tubing staying in place without my custom made standards i choose to mount 2 at the end of the pedestel. More solid.
Thats all for today.
