18-01-2018 Package.
I received the parts that i orderd from watercoolingshop Highflow.nl.
I've read the review from Extreme Rigs about the review the made about "Mayhems Borosilicate Glass Tubing" from 0ct,20,2015.
A few things that are on my mind about the tubing;
- are the measurements of the OD like the say;
- are the HDC fitting from EKWB the ones that i need;
- can i make the bending and cuts "first i have to make a cutting table, like showed in the youtube film made by Extreme Rigs.
The first thing i did was measuring up the OD of the Mayhems 16mm tubing.
For practice i have 3 tubes "length 50cm".
I use the caliper for home use "crappy flindstone one".
The measurements i got where 2 x 16,09mm and one 16,14mm. After mounting the first connector i must say a good combination.
Because the reading on the box is in englisch whe dutch have a small problem if whe cant traslate the words. Lucky for me i have Englisch at my scool 42 years ago.
But also for the people who can read Englisch there are things to take care off "about the fitting";
- dont use with aluminium "for that i changed my radiators already";
- use Allen Key for mounting to waterblock;
- dont use tool to tiden the ring;
- chamfer the tube 0,5mm angle 45 degree.
One thing i forgot because was in a hurry for ordering the parts "ordering a 9mm Allen Key".
Because i dont have one i will make one out of a 10mm Allen Key.
I also received the waterblock for my Asus GTX1080Ti-FE 11gb founder edition.
I hope to get a second one in a few months.
The next thing i have to do is make a drawing for the cutting table for the Mayhems Borosilicate Glass Tubing.
A few Pictures.
