1 - 20 of 148 Posts
ლ(╹ε╹ლ)
✨ Seasonic with a Seasonic 650 Prime 80+ Titanium ✨ SeaSonic.com
✨ NZXT with RGB for days (HUE+) and 6* AER F performance fans with white trims! ✨ NZXT.com
✨ Monsoon Cooling with watercooling gear! ✨ MonsoonCooling.com
✨ CableMod with Custom RGB Extensions! ✨ CableMod.com
✨ Apacer with so much NAND goodness! ✨ Apacer.com
  • CPU - i7 7700K (Have) from @Silicon Lottery, (SiliconLottery.com)
  • RAM - 4*8GB Apacer BLADE FIRE DDR4 8GB 3000Mhz [SPONSORED]
  • Motherboard - Gigabyte Z270MX Gaming 5, RGB (Have)
  • GPU - MSI 290X Lightning (Have)
  • Storage SSD 1 - Apacer Z280 M.2 PCIe SSD 240GB (Have) (OS + Steam) [SPONSORED]
  • Storage SSD 2 - Apacer AS330 SSD 240GB(Have) (B.net + Origin) [SPONSORED]
  • Storage HDD - Seagate 4TB Barracuda 2.5" (Have)
  • PSU - Seasonic 650 Prime 80+ Titanium (Have) [SPONSORED]
  • Case - Case Labs SM5 - White (Have)
  • Keyboard - G.Skill KM570 RGB (Have)
  • Mouse - Nixeus Revel RGB-ish (Have)
  • USB upgrade - NZXT Internal USB 2.0 Hub (Have) [SPONSORED]
  • Lights - NZXT Hue+ RGB (Have) [SPONSORED]
  • CPU - Alphacool NexXxoS XP3 Light - Acetal (Have)
  • GPU - EKWB FC 290X Lightning block (Have)
  • Pump - EK PWM D5 G2 (Have)
  • Reservoir -Monsoon MMRS 150mm, D5 mount, All black with Frosted plexi. (Have) [SPONSORED]
  • Radiator 1 - EK Coolstream XE 360 (Have)
  • Radiator 2 - EK Coolstream PE 360 (Have)
  • Fans - NZXT AER F 120mm with white trim (x6) (Have) [SPONSORED]
  • Fan Hub - Swiftech PWM Hub (Have)
  • Tube Fittings - Monsoon EV2 1/2"x3/8" - black (Have) [SPONSORED]
  • Angled Fittings - Monsoon 45 Rotary Angle 1/2" OD - Black (Have) [SPONSORED]
  • Tubing - Monsoon 3/8"x1/2" PETG - Black (Have) [SPONSORED]
  • Coolant - Mayhems Pastel black (Have)
  • Extras - Monsoon Bending Kit (Have) [SPONSORED]
ლ(╹ε╹ლ)
It's a me
Asus Strix GPU's are RGB. At least my RX470 is.
Oh and I believe some high end Rosewill PSU's have those modular hookups that are multicolor if not RGB.
Maybe a bit too much color
ლ(╹ε╹ლ)
I think I'll just use what I have now.
For that PSU. no. I want RedGreenBlue not Red. Green. Blue.
I find your avatar oddly satisfying with this build theme - definitely in for the journey.
Senioritis Member
I love your new Avatar!
Amiga 500
You got me at ✨RGB✨ , lol
Subbed
Meep
Subbed!
Why that cooler in this build though? Seems like an odd choice in a case with 191mm of clearance.
Why not the LEPA NEOllusion considering the RGB theme?
Senioritis Member
Originally Posted by Gilles3000 View Post
Subbed!
Read Duality92's review on that cooler to get an idea why he is going to use it. I would consider putting it my new build instead of the Noctua NH-D15s I already have if it wasn't for the fact I would lose my top PCI-e slot.
ლ(╹ε╹ლ)
Discussion Starter · #14 ·
Subbed!
How do you know what case I'm using?
Also because it's compact and I love the aesthetics of it. It's not overwhelmingly big like its performance rivals.
Did you see also how loud it gets at 100% fan????
Meep
Already did before posting here, posted my opinion of it in the comments below.
Going from your D15S to the HEX2.0 would be a side grade at best, and most definitely louder. The compatibility issues with the HEX just makes it even more of an odd product, the only place it really makes sense is in SFF builds but it blocks the fist pcie slot on most motherboards, I guess you could make it work with back to front airflow in some cases, but really?
It might make some sense in some extremely niche application, but it just seems like a really tough to justify product to me.
Just a slightly educated guess, could be wrong , but I think my guess is pretty solid.
Fair enough, its does look pretty nice, and leaves a lot of the motherboard exposed. I'm personally quite fond of big air coolers, but I definitely see where you're coming from.
Edit:
Sure did, just a little louder than most high end air coolers. which is very reasonable considering the ~2500rpm fan speed.
ლ(╹ε╹ლ)
Discussion Starter · #16 ·
PM your guess for a case
As for the cooler, I got it for review, but without actually using it, I would've been very hesitant to buy it.
think i am really going to enjoy this one too. i have the gskill ripjaw 780 keyboard and mouse. i use the m1 (memory 1) for the division and the 2 for ghost recon wildlands, still need more lighting on my rig though.
1 - 20 of 148 Posts
