Update 30 Sept 2013.
This is going to be the complete parts list of everything I will use I will be updating this over the next week adding to it and also adding links.
Computer Hardware
Gaming/Encoding PC
Media and File Server
Storage/Back-up Server
TVPC This will be for my Wife to watch TV From the internet.
Movie PC This will be for my daughter to watch movies from the server and also iTunes.
For Networking
Netgear 8-Port 10-Gigabit ProSafe Plus Switch XS708E-100NES
Water Cooling Parts
Gaming/Encoding PC Chilled Water Cooled (Going to use Chilled water from a custom TEC water chiller)
TVPC
Movie PC
Water Chiller Hot Side Cooling
All this is Going in a Case Labs TX10-D with triple Pedestals and 150mm Top.
Now this is Excessive Insanity
Computer Hardware
Gaming/Encoding PC
CPU: Intel i7 3930k
Motherboard: Asus Rampage IV Extreme
Memory: G.SKILL Ripjaws Z Series 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400
GPU: 2 x EVGA Titan
OS: Windows 7 Ultimate
OS/ Program Drive:Raid 0 of 2 X Samsung 840 Pro 512GB
PSU: EVGA SuperNOVA NEX 1500
Raid Card:LSI Logic MegaRAID SAS 9271-8iCC
Raid Expander Card:Intel Raid Expander RES2CV240 24 Port SAS 6GB Expander Card
Storage Drive 1:Raid 0 of 8 X 120 GB SSD's In a Raid 0
Storage Drive 2:Raid 0 of 4 X Samsung EVO 250GB SSD
NIC Card: INTEL X540-T2 DUAL PORT 10GB ETHERNET
GPU: 2 x EVGA Titan
CPU:Core i5 4670K
Motherboard: Asus Z87 WS
Memory: G.SKILL Sniper Gaming Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
GPU: On Board
OS:Windows Server 2012 Essentials
OS/ Program Drive: Raid 10 of 4 X Western Digital VelociRaptor 500GB 10000 RPM 64MB Cache
Raid Card:2 X LSI MegaRAID 9265-8i with CacheCade Pro 2.0/Fastpath
Raid Expander Card:2 X Intel Raid Expander RES2CV240 24 Port SAS 6GB Expander Card
Storage Drives:
GPU: On Board
Storage Drives:
- Raid 5 of 8 X WD VelociRaptor 600GB 10000 RPM Array Size 3.8 TB
- Raid 5 of 6 X Savvio 10k.2 146GB 2.5" 10k RPM SAS HDD Array Size 680GB
- Raid 5 of 6 X Seagate T10 146GB 15k RPM SAS HDD Array Size 680 GB
- Raid 5 of 6 X HP 300GB 15K RPM SAS HDD Array Size 1.4 TB
- Raid 5 of 8 X WD Scorpio Black 750GB 7200RPM SATA HDD Array Size 4.8 TB
- Raid 5 of 4 X Seagate Barracuda 3 TB HDD SATA 7200RPM Array Size 8.2 TB
- Total Storage Space 19.56
CPU:Core i5 4570S
Motherboard: ASUS GRYPHON Z87 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 uATX
Memory: GeIL Black Dragon 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333
GPU: On Board
OS/ Program Drive: Raid 1 of 2 X Samsung 840 Pro 250 GB
PSU: OCZ ZT Series 550W Fully-Modular
Raid Card:LSI MegaRaid SAS 9260-8i SATA+SAS Controller Card
Storage Drives:Raid 50 of 9 X Seagate Barracuda 3 TB HDD SATA 7200RPM Array Size 19.1 TB
NIC Card:INTEL X540-T2 DUAL PORT 10GB ETHERNET
GPU: On Board
CPU:Core i5 4570
Motherboard: ASRock H87M-ITX LGA 1150
Memory: ADATA XPG Gaming Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
GPU: On Board
OS/ Program Drive: Raid 1 of 2 X SanDisk Ultra Plus 128 GB SSD's
NIC:ON Board
GPU: On Board
NIC:ON Board
CPU:Core i5 4570
GPU: On Board
Storage Drive:Raid 1 of 2 X Western Digital Caviar Blue 1 TB,Internal,7200 RPM
GPU: On Board
For Networking
Water Cooling Parts
CPU Water Block:EK Supremacy Clean CSQ
Motherboard Block :EK-FB KIT RE4 CSQ
Memory Blocks: 2 X EK-TOP Plexi - RAM Monarch X4 Clean CSQ with 8 X EK RAM DIMM Module
GPU Blocks: 2 x EK-FC GeForce GTX Clean Clear Plexi with EK Back Plates
Pumps and Tops 2 X EK D5 Dual CSQ Pump Top - Acetal - Black with 2 X Alphacool VPP655 Pumps and 400mm Reservoir Each.
3rd Reservoir & Pump 400mm EK-RES X3 and Swiftech MCP35X2 with 2 Swiftech MCP35X pumps
Radiators:
Radiators:
- 2 X EK-CoolStream RAD XTC with 6 Gentle Typhoon AP-15's In Push/Pull using Begears 140mm to 120mm Fan Adapters
- Watercool MO-RA3 9x140mm Pro - Black Cooled with 18 Noiseblocker NB-BlackSilentPro PK-PS 140mm PMW Fans
CPU Water Block: EK-Supremacy Clean CSQ - Acetal with the Gold Hardware
Memory Water Block: EK-TOP Plexi - RAM Monarch X4 Clean CSQ with 8 X EK RAM DIMM Module
Pump and Reservoir EK- EK-D5 X-TOP CSQ -Acetal with a 250mm Reservoir
Radiator's:
Radiator's:
- Alphacool NexXxoS Monsta Single 120mm Radiator - Custom Painted White with 2 Noiseblocker NB-eLoop B12-3
- EK-CoolStream RAD XT (360) With 6 Gentle Typhoon AP-15's In Push/Pull
CPU: Core i5 4570S
Pump and Reservoir EK-Reservoir Combo DCP 4.0 145ml reservoir with EK-DCP 4.0 pump
Radiator EK-CoolStream RAD XTC (140) with 2 X Swiftech Helix 140MM in Push/Pull
TVPC
CPU:EK-Supremacy Clean CSQ - Acetal
Pump and Reservoir EK-DCP 2.2 (12V DC Pump) with EK-DCP 2.2 X-RES Combo Reservoir
RadiatorsAlphacool NexXxoS UT60 Full Copper 120mm With 1 Noiseblocker NB-eLoop B12-3
Movie PC
RadiatorsEK-CoolStream RAD XTC (140) with 2 X Swiftech Helix 140MM in Push/Pull
Reservoir:2 X Massive Custom FrozenQ Reservoir
Pump's:2 X Eheim 1262 900GPH Universal pump's
Radiators:
Radiators:
- 4 X Alphacool NexXxoS UT60 Full Copper 560mm with 8 Koolance Fan, 120x25mm (FAN-12025HBK) mounted with Bitspower 120 to 140 Fan adapters on each Radiator
- 2 X Alphacool NexXxoS XT45 180 triple with 3 SilverStone SST-AP182 Air Penetrator 180mm Case Fan each
