Realization
The first challenge was the size of the new radiator. I underestimated it a bit
Original plan was to use it together with the existing 240 mm and 120 mm radiators. But there's not enough room to use all three together, so I decided to only use the new one. I also didn't like the fragmented look of the three radis in three different sizes at one place.
This had been a first scetch:
https://abload.de/image.php?img=radiatorgehuserundecka1sw5.jpg
Later on I changed it to a concept with pushing instead of pulling fans.
The assembly concept is subject to one credo: the overall construction has to be as maintenance-friendly as possible. To ensure this the radiator is placed on guide rods. He will be hold in place by magnets glued into the rods. By this he can be unmounted for service without loosening a screw.
The fans will be mounted the same way.
https://abload.de/image.php?img=explosionradiatorv1zlsef.jpg
First parts manufactured using the old mill at work:
https://abload.de/image.php?img=dsc06682wtsr1.jpg
Since I have no education for the usage of such machines this manufacturing takes long time for me.
I had to manufacture some inlays made from magnetic steel to mount them into the radiator mountings. They'e needed for the magnets in the rods to hold onto. I used a foil to make them look better.
http://abload.de/image.php?img=dsc06687gykqc.jpg
