I did a few modding experiences lately, namely plastidipping a motherboard along with paint hydro dipping, I wanted to gain knowledge regarding these two modding techniques. I say both went VERY well! The only downside, is that I'm not sure where or how, but the motherboard LEDs do not work anymore appart from the I/O shield which stays purple. I'll eventually be tearing the whole thing down again and reassembling the motherboard to make sure everything is connected as it should.
Anyways, I learned a lot on this project and I think the results are still quite good! I had to mod this InWin USA 103 to fit an Alphacool English UT60 360 in Push/Pull! (110mm total thickness!). There was a bracket up top which needed a lot of trimming since it holds both the dual hard drive bay along with the I/O ports so I could not just remove it!
Intel i9 9900K
AORUS Z390 Xtreme
TeamGroup Dark Z 3200 MHz
GIGABYTE RTX 2070 Super OC
Seasonic Prime Ultra Titanium 850W
CableMod Custom Pro ModMesh cables
Alphacool Watercooling all around (except water block)
Watercool HeatKiller Acetal Nicklet waterblock
Apacer Global Z280 256GB NVME SSD
