1 - 20 of 167 Posts
Hi there:)
I'm quite new to this forum, but since they liked my build at some Dutch hardware sites, i wanted to post it here too.
My other build came to an end and didn't know what to improve, but my old desk almost fell apart.
Really want to thank Pascal for his pc-in-a-desk idea. After seeing it I couldn't even sleep that night
I started sketching it with Google Sketchup
After 9 hours of non-stop drawing it finally had some shape.
Hardware to be used:
(Most of it comes out of my old build)
Intel Core i7 980X @ 4.5 Ghz
Corsair Dominator GT 6GB DDR3-2000 CL7 (Elpida) @ 2000 7-7-7-20-1T
ASUS Rampage III Extreme
2 x ASUS GTX580
ASUS Xense
Sennheiser Xense
Highpoint RocketRAID 3560 24x SATA-300 2 GB
Bigfoot Networks™ Killer™ 2100 Gaming Network Card
1x Intel 510 120GB
3x Corsair F60 raid0
6x Hitachi Deskstar 7K2000 2TB raid5
2x Optiarc AD-7241S-0B
2 x Coolermaster Silent Pro 700W
Dell U2711 27″ IPS
2x Dell 1703 FPt 17″ portrait
Blocks
1 x EK Supreme HF Nickel CPU Block
2 x EK-FC580 GTX - Nickel
2 x EK-FC580 GTX Backplate - Nickel plated
1 x EK RAM Dominator Nickel
1 x EK-FB RE3 - Nickel
1 x EK-FB RE3 - TOP Acetal - Level 2
2 x Bitspower HDD Acetal Liquid Cooling Block - Silver
Pumps
2 x Laing D5-MCP655
2 x Bitspower D5/MCP655 Mod Pump Top V2
2 x Bitspower Black Sparkle D5/MCP655 Mod Kit
Reservoir
1 x Aquacomputer Aquatube G1/4 brass
Radiator
1 x Aquacomputer evo 1080
Fans
6 x Nanoxia DX Series 120MM DX12 - 1200RPM @ 5V
11 x Scythe Gentle Typhoon 120MM 1450RPM @ 12V
Fittings etc
24 x Bitspower Black Sparkle Multi-Link (SLI/CF) Adapter
16 x Bitspower Black Sparkle G1/4 Rotary 90 Degree IG1/4 Adapter
12 x Bitspower Black Sparkle G1/4 naar G1/4 (2x OD) Verbindingsstuk
10 x Bitspower Black Sparkle G1/4 Stop Fitting
8 x Bitspower Black Sparkle 13MM (1/2) Schroeffitting - G1/4
6 x Bitspower Black Sparkle G1/4 Rotary 90 Degree ID 1/4 Adapter
6 x Bitspower Black Sparkle G1/4 IG1/4 Extender
4 x Bitspower Black Sparkle G1/4 Five Rotary Snake-Style Dual IG1/4 Adapter
4 x Bitspower Black Sparkle G1/4 Rotary 45 Degree IG1/4 Adapter
2 x Bitspower Black Sparkle G1/4 Triple Rotary Mini Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Triple Rotary Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Rotary IG1/4 Extender
5 x Bitspower Crystal Link Tube For 5-Slots (SLI/CF)
8 x Bitspower Silver Shining 2xG1/4″ Fillport
2 x Bitspower Silver Shining G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini
2 x Bitspower Matt Black 2xG1/4″ Fillport
2 x Bitspower Matt Black 13MM (1/2)Schroeffitting - G1/4
1 x Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17
2 x Thermosensor G1/4 2x ID In-Line met Display (blue)
2 x Colder 13MM (1/2) Snelkoppeling Set
2 m Tygon R3400 1/2 ID Black
2 m Tygon R3603 1/2 ID Clear
3 L Feser One Cooling Fluid - UV Acid Green
I'm also gonna use my old cooling again since it works superb.
It's a 1080 radiator under my floor from my house, right in the corner where my pc is.
My water temperature in wintertime is around 18 degrees, in the summer it's around 23 degrees.
Here some Youtube movies:
Underground radiator
[ame]http://www.youtube.com/watch?v=WpBDQ9XXFGo[/ame]
The Final Fill-up
[ame]http://www.youtube.com/watch?v=pr1_UmJB5ik[/ame]
Silence of the L3p D3sk
[ame]http://www.youtube.com/watch?v=CTv2hEfeFP4[/ame]
Sponsored by:
Discussion Starter · #2 ·
Here are the final pictures i made for some Casemod contest.
Still got some small mods (One really cool one) to do in the future so it isnt completely finished yet.
After these pictures i'll fill up this thread with the complete buildlog
All these pictures are clickable to the original 3600x2900 resolution pictures
Have fun !
Originally Posted by l3p;13618054
Thanks a lot man !
I didn't know what happened a few days ago, some people went crazy about it
Got tipped there are a lot of modding lovers here so though why not post the complete buildlog here.
Actually I think someone in here posted a link to a different forum where you might have been posting your worklog. I Read the whole thread because of this massive and perfect build - Really its nice.
And thumbs up for you "underfloor rad"
.. Never seen a solution like that before
.. Thumbs up from Denmark!
Great work L3p. Truly inspirational.
I'd been dreaming about something like this for a while then saw your work over at [H] around December last year and that was that. Had to get my version cranked out heh. I even tried blaming you when the wife went ballistic over the cost lol.. Lucky you it didn't work in my favor.
I definitely wouldn't have made mine if it wasn't for your awesome work. +rep
Damm dude thats a sick idea!
you did a great job!
+1 Rep for the mod
*groeten uit brabant ^^*
Discussion Starter · #16 ·
Dank je Nightm4re ! ^^
Since im already busy with this project for 8 months now, here are all the pics in one post.
Started with an Aluminium plate of 1850x990x3
Plates for the mainboard tray, hdd tray, pump/res tray and cable plate
The bearer ring to hold my desk
Been to an other company to make a logo
And back to welding
Plasmacutter to make some cable holes
Discussion Starter · #17 ·
End of the first long day
Creating a logo (was just a try, worked out well)
Made some holes for the lcd's for the in and outgoing water temperature, and for the logo
Had to make some changes to let my knees fit
Fitting the trays with sound isolation under it.
I love packages !
Thought the buttons would the same, gonna change for 2 big one's now.
Sound isolating for under my trays.
My best friend welding
Holes for the Bitspower fanguards
Both sides will have 3x 120mm Scythe Gentle Typhoons 1450 rpm op 5V
Underground will be 9x 120mm Scythe Gentle Typhoons 1450 rpm op 12V @ the 1080 radiator
Thats me !
Discussion Starter · #20 ·
Forgot a hole
So made it bigger
Mess outside
Made 2 extra 120mm fan holes in the cable-space, cause i decided my psu will come there too.
And made the hole for the lianli backplate.
Bitspower !
And building everything back for the hole picture
Shopping time
Measuring the last holes.
And more measuring
Muscle pain !
Rear = ready
And the front !
1 - 20 of 167 Posts
