1 - 20 of 67 Posts
Hi, here you can find my new project based on a Silverstone TJ07, old but gold, you can see my project below.
I'll start it really soon….stay tuned
Project:
Discussion Starter #4
Thanks to Noctua for the partecipation in this new mod, really good and high quality products, sheer power
Discussion Starter #6
Huge thanks to PC-Teklab, this motherboard is amazing, I'm waiting for a i7 6700k and we will see some good stuff
Nice work. Did the TJ07 change at some point in time, I remember mine having the two rear 90mm fans whereas yours doesn't?
Discussion Starter #11
you have some version, mine is without the two fans in the back and don't have the window, I'll do with laser cut another one adding the window and 4mm glass
Discussion Starter #15
Thank's to Aquatuning for the support in this project, here you can see something that i received
Discussion Starter #16
I use 2 x 360mm radiator stands but they doesn't feet in the j07 so I had to cut them and modify, I'll paint them again for a better look
1 - 20 of 67 Posts
