[SPONSORED] PARVUM JAWS
17560 Views 130 Replies 29 Participants Last post by  Goofy Flow
I'm so excited to start a new build with the support of awesome guys from Parvum Systems which I'd like to thank for their work and for their willingness, what else brand in the world is so attentive to own customer? Not many I would say!
This build is dedicated at one of the best films of all time, at least for me but I hope for you too, and one of the most famous Spielberg's movie, Jaws.
The basic idea is inspired by one of my favorite build ever, called "Xenomorph" of Akira749, namely to recreate the features of a creature / monster / villain (the xenomorph in the akira's build and the shark in mine) and the "atmospheres" of the movie.
First, I explained to Justin my ideas for the subject and for the most suitable color scheme, then he designed the render in my place.
The case is rich of details, the shark bites are just what I wanted, they give a very personalized look to the entire case, the movie logo is the cherry on the cake.
Sponsor & Support
Solid Strands
Parvum Systems
ColdZero
Mayhems
Main Components
Case - Parvum Systems S2.5 (Custom Themed)
CPU - Intel i7-7700K
Motherboard - Maximus VIII GENE
Memory - 32GB HyperX Savage DDR4 2800MHz
GPU - Asus Strix 1080 Ti
SSD - Crucial MX500 1000GB
PSU - EVGA G3 750W Supernova
Watercooling Components
CPU Block - EK-Supremacy EVO - Full Nickel
GPU Block - EK-FC1080 GTX Ti Strix - Acetal+Nickel
Radiators - Alphacool NexXxoS ST30 Full Copper XFlow 240mm - Alphacool NexXxoS XT45 Full Copper 240mm
Pump/Res - EK-XRES 140 DDC 3.2 PWM Elite (incl.pump)
Fittings - EK all Nickel
Tubing - EK-HD PETG Tube 10/12mm / Copper nickel-plated tube OD 12mm
Coolant - Mayhems Dye Blu / Mayhems Ocean Blu
Miscellaneous
Fans - 4 x EK-Vardar EVO RGB 120mm
Cables - MDCP-X Blue-Carbon Custom Sleeved Cables
121 - 131 of 131 Posts
· Acrylic cases
Discussion Starter · #123 · (Edited)
I re-uploaded all the final pics after I realized that the white balance was quite warm (I previously set the WB at 5500K that's fine with my laptop, but for some reason it was too warm for my calibrated monitor), so I had to re-edit everything with a new WB dropped to 5000K and I also increased a bit the saturation to reach a deeper blue.
I think it's fine now!
· Acrylic cases
Discussion Starter · #127 · (Edited)
Ok, after more than year, I decide to upgrading my Parvum JAWS with a new gpu as well as nickel plated tubing.
I move the reservoir and pump in the rear chamber and connected them using the pass-through in the original 20 mm holes.
Here a couple of pics with the stock vga cooler (ekwb waterblock coming soon).
· Acrylic cases
Discussion Starter · #128 ·
Full cover installed, now it's time for the loop.
I'll stay with nickel plated copper, hard to work but definitely the better hd tubes out there, just need to decide if go with the bent tubing or straights tubing with 90° fittings.
