1 - 20 of 1250 Posts
Computer Art
Here we go yet again! Here's my first of two builds this fall, another team up with Parvum Systems, this time for a highly customized Advanced Warfare themed mITX build. Originally I was set for a totally different theme but then last week at Gamescom Microsoft showed off their limited Advanced Warfare controller and console. I then switched themes and have decided to tread familiar ground in doing a build inspired by another Xbox One controller. I just couldn't help myself. I'm pretty inspired by the controllers color pallet, it's very unique and I think this build will turn out completely amazing with the plans I have...
This build is possible with the support of Swiftech, DazMode, Darkside, Ensourced Cables, and of course the talented lads at Parvum Systems.
Here's the controller I'll be using for the inspiration here:
Main Components:
Case - Parvum Systems custom mITX
CPU - Intel 4790k
Motherboard - EVGA Z97 Stinger
Memory - GSkill 16Gb 1866
GPU - Nvidia Titan Black
SSD - Samsung EVO 500Gb
PSU - Corsair RM650
Watercooling Components:
CPU Block - Swiftech Apogee XL
GPU Block - Swiftech Komodo NV LE
Radiators - Darkside 120mm and 240mm
Ram Block - Bitspower
Pump - Swiftech MCP 35X
Pump Housing - Bitspower
Reservoir/Pump Top Combo - Bitspower
Fittings - Bitspower True Brass
Tubing - E22 12mm OD acrylic tube
Coolant - (still undecided)
Miscellaneous:
Ensourced custom cables
Darkside lighting
Custom vinyl and paintwork by me
Fans - Enermax Twister Pressure
I don't have 100% of the components chosen yet, but I'm almost there. Parvum currently has my case design mockup and will be starting it next week - it's going to be spectacular. I'll update this component list as things progress.
Thank you all for the support and following of my previous builds. The community feedback from the Robocop build, and especially the Titanfall build, has truly been overwhelming and I owe it all to you. Let's get this thing started!!!
Progress Index
1. Motherboard and CPU
2. Fittings and pump bottom!
3. The GPU and a box from Swiftech...
4. The Swiftech Apogee XL and KOMODO NV LE
5. Darkside radiators from DazMode
6. Fannnnzzzzzz...
7. PSU, Ram and SSD
8. Swiftech pump/res combo complete
9. Ram heat sinks installed
10. Custom Swiftech block pieces
11. Vinyl cutting tutorial
12. Swiftech block installed on motherboard
13. Case teaser from Parvum Systems
14. Customized PSU done
15. Fannnnzzz... part 2
16. Custom SSD done
17. Parvum case reveal video
18. Case picture gallery
19. Case graphics complete!
20. Replacement ram done...
21. Fluid!
22. Front rad and fans installed, reservoir positioning, and I/O shroud done
23. Custom cables from Ensourced arrived!
24. All loop pass-throughs drilled, loop ready to install
25. Happy "Advanced Warfare" Halloween!
26. Loop is installed!
27. Darkside Lighting
28: Finished Build Unveil Video
29. Final photos!!! Thanks everyone!
Computer Art
Originally Posted by Pheozero View Post
I lost interest in CoD a long time ago, but I must say, that controller is amazingly sexy.
I honestly did too, but in addition to being inspired by that controller the game is seriously looking good, I must admit
That controller is next level, a build in that theme is gonna be awesome! subbed
So subbed to this. But y'know? You should do something like matte nickel plated copper tubing in this build imo, rather than acrylic. It would fit the theme of it really really nicely given the color palette of that controller that you are deriving inspiration from.
Computer Art
Discussion Starter · #12 ·
Anything is possible... That's a good idea. My other upcoming build is specifically using copper so I have a lot. The only thing with the tubing/coolant is that it has to perfectly complement the gold fittings. I have the color balance and design worked out pretty well in my head, the only thing I'm really not sure about is the coolant. I will keep the tube idea in mind
Fusion is Future
Yes yes yes !!!
Amiga 500
Subbed of course for greatness and head shots
The color scheme of the controller makes me more anxious to see the Parvum case
