1 - 20 of 398 Posts
Moderator
Project Rose - A Car-puter by axipher
Android/AMD APU Entertainment System in a 2007 Honda Accord SE
Introduction
Welcome to my latest project, Project Rose. This is something that I've often thought about doing but could never justify buying a new system just for my car. Thankfully, with a few build logs under my belt, I've managed to get some sponsorship started for w truly unique build.
It all started with some talks with Rob over at AMD whom I met at the OCN Grand Champion Series in Toronto, ON over Canada Day weekend. He managed to get me in touch with the right people and got my build kicked off with a big bang with a AMD A8-3870k. I've never played with an APU myself other then a couple lower end ones in builds for friends so I'm really looking forward to doing a nice review of the chip and seeing how well it performs in a car-based entertainment system.
This project has slowly grown in to something much bigger than originally planned and has acted as a base for me to test new DIY, work with new materials, and push me to learn new theory and techniques.
I'm currently looking in to securing some more sponsorship so I can truly make this build the best it can be by focusing my own funds on the car itself in preparation for the new system.
I'm going to spend as much time as I can on this thread making it the best it can be as well so please feel free to give me any constructive critcism that you have in regards to the thread or the build itself. It's my first car-puter build, but not my first time working with car audio systems so I'm not worried at all.
Project Overview
  • Full entertainment system
  • Install a GPS program Use Android GPS program, either Maps or Co-Pilot
  • Allow for input from an external audio and video source
  • Custom mounting bracket for 7" Nexus 7
  • Custom case built inside my glovebox with some clever duct work I have planned to get rid of the heat
  • Completely re-wire the entire speaker system
  • Design a custom box for all the audio equipment in the trunk within the spare-tire area
  • Upgrade the car's electrical system
  • Possible LED TV or projector in the trunk as well
  • Fully sleeve the build
  • Run EL-Wire and LED's as accents
  • Update front bumper with fog lights
  • Integrate light controls in to Car-Puter
List of Resource Threads
List of Resource Sits
Table of Contents
IntroductionPost #1
SponsorsPost #2
Video LogPost #3
Block Diagram Log Post #4
Picture Log Post #5
Acquired Lutro0 as a sponsor Post #17
Version 1 of block diagram Post #19
Pictures of the cars interior Post #33
EL-Wire accents Post #134
Pictures of trunk (Before) Post #136
More Pictures of trunk (Before) Post #146
Massive amp, cap & sub re-wiring & Skippy Post #153
Stella's band-aid and first stereo competition Post #179
Stella's 3rd place trophy Post #182
New media panel and ODD idea Post #187
AMD A8-3870k Received Post #201
Electrical Brain-storming Part 1 Post #221
Electrical Brain-storming Part 2 Post #226
Electrical Brain-storming Part 3 Post #242
Electrical Sequence of Events Post #247
Sound system woes Post #257
Temporary Sound System Update Post #272
Custom 4-channel A/B Switch Post #286
Car Show DJ setup Post #292
List of parts
PartModelConfirmedSponsoredIn-Hand
CPUA8-3870kYes
Yes
No
SleevingMiscYes
Yes
No
Amplifier (Sub-woofer)Alpine MRP-M500YesNoYes
Amplifier (Sub-woofer)Alpine MRP-M1000NoNoNo
Amplifier (Speakers)Alpine KTP-445uYesNoYes
Sub-woofer
Alpine SWR-1022dYesNoYes
Front SpeakersAlpine SPR-60cYesNoYes
Read SpeakerAlpine SPR-69YesNoYes
PSUM4-ATX
No
NoNo
Touch ScreenVM7000NoNoNo
EL-WireVarious RedNoNoNo
DVD MountSilverstone FP58BNoNoNo
DVD DriveSilverstone SOD02NoNoNo
Single DIN > 5.25" AdapterTBDNoNoNo
Completed Tasks
  • Received sponsorship form AMD
  • Received sponsorship form Lutro0
  • Ran 3-pair RCA to trunk for sub and speaker amps
  • Designed and built custom 4-channel A/B switch for external speakers
To-do list
  • Design custom mounting box for spare-tire well
  • Design and install lighting
  • Plan power for computer
  • Prep in-dash mount for LCD touchscreen
  • Plan the sleeving
Moderator
Discussion Starter #2
List of Sponsors
1000
1000
Moderator
Video Log
Coming soon!
Moderator
Discussion Starter #4
Block Diagram Log
Version 1
1000
Moderator
Discussion Starter #5
Picture Log
Stella, completely stock aside from the stereo system
Finally some pictures of the interior before doing anything
1000
Factory deck on top, Alpine CDA-105L on the bottom to be replaced
1000
Close-up of existing deck and possible future location of LCD screen
1000
The brains of Project Rose's home, needs a little cleaning, custom vents, and a mounting system
1000
The amp and sub's home
Rubber trunk mat with raised edges soaking in a soap solution
Alpine Type-R 10" Deep SWR-1022D (Dual 2 ohm)
Alpine MRP-M500 350 W RMS @ 4ohm + 500 uF cap + Hydraulic Jack + 10A Battery Charger with Jump Start feature
Full-size spare winter tire (that puny donut tire in the spare tire well is retired to make room for the amp)
Front Tweeter location:
Sub and spare-tire only in the trunk (normally I have a bunch of tools and auto supplies)
Just the spare tire and a mysterious extension cord (but where's the amp and how is the sub connected)
Spare-tire well re-organized temporarily until I build a insert out of plywood to mount everything to
Just another shot of the spare tire well
Sub connection (super easy removal was a key feature)
That's what the extension cord was for
Hides nicely behind the sub box
Normally it's actually hidden, but just showing where it runs
Stella just strutting her stuff
Where the wiring comes from
Nice and secure ground lug
Little behind the scenes cable-management
All cleaned up for the car show on Sunday
All cleaned up and waxed for the car show
On display at the car-show
Trunk emptied out aside form the sub
3rd place trophy for loudest sound system in the amateur trunk division
Somewhat organized spare-tire well
Passenger side cables
Removind the head unit, shifter cover plate first, then ash tray, then mounting bracket
Really messy internals
Cleaned up a little for the new amp
Configuring the new amp
Project Rose and my buddies Sunfire
Speaker + Laptop setup
Using Mixxx for DJ-ing
Work in progress sound system
Moderator
Discussion Starter #6
Reserved
Im planning on doing something similar to my eclipse. I use a program to tune it that requires a laptop and my radio is outdated and wont play .flac or .wav files so I decided it would be a little cheaper to build a small atom machine or similar and throw it in there along with a 7" lillyput touch screen. Good luck to you and I look forward to seeing some progress.
HDMI? Posted in nix section, thought I'd get this too for ya.
Moderator
Discussion Starter #13
Originally Posted by Lutro0 View Post
In on this one. =)
I'll try not to disappoint, I still yet to even try sleeving so it should be interesting.
Originally Posted by Adrenaline View Post
Yes axipher ! This is Going to be Amazing
havent seen a Build Log for a Car-Puter.
Thanks :D
Well lucky for you, you have a friend that will help.
Moderator
Discussion Starter #15
Yep :D
I'm sure I'll have a bunch more questions for you on this build lol.
Moderator
Discussion Starter #17
I would like to take this chance to welcome Lutro0 on as a sponsor for this build, really looking forward to working with him on my 3rd project now.
1000
Subbed. Subbed, just subbed.
Moderator
Discussion Starter #19
Here is my first shot at the block diagram for Project Rose:
1000
back at it
subbed, not the first carputer log but seems interesting sir! also subbing because you made my mind about the future server
1 - 20 of 398 Posts
