Icy Blue Angel II
I choose to do a new build log instead of an update because only I keep only the case, fan, cpu and motherboard
all other parts will be new
and go for a full Bitspower build
Steps 1: Ordering parts
Computer parts
CPU: Intel i5-4670k: received
Mobo: Asus Z87 Gryphon: received
Ram: 16BG (4 x 4) Corsair Dominator GT : received
GPU: 2 x Zotac GeForce GTX 780 OC: received
Case: *** coming soon *** received
Power Supply: Silverstone Strider 1000w: received
SSD: 1 x Crucial M100 256Gb : received
Mods Parts
Sleeving: darkside White, silver and Blue Sleeving: received
Case lightning: 3 x Darkside - 12" white LED strips received
GPU backplate: 2 x ColdZero custom Backplate GTX780:received
a lot of Darkside fans splitter and molex spliter: received
Paint and a lots of little things
Case and Radiator fans: 6 x Bitfenix Spectre led Blue: received
Radiator: 1 x Darkside LP240 and 1 x Darkside LP360: received]
CPU: Bitspower Summit intel: received
GPU: 2 x Bitspower VG-NGTX780TI Nickel Plated: [/B]received
Pump: 1 x DDC 3.1: received
Pump Top: DDc Bitspower Pump top Clear, received
Reservoir: Bitspower - Z-Tank 250 (Clear Cap) received
Tubing: E22 plexi tube 12mm/10mm: received
Coolant: 2 x Mayhems Bluberry: received
Fittings: a truck load of Bitspower Multi-Link Adapter BP-MBWP-C47: received
Fittings: Bitspower 90, spacer and rotary 90 degre white fitings: received
Star working on painting and color test
loll, no choice on color, my wife want pastel blueberry blue,
some pics of the summit
seriously, i like the Summit, in real life, look really amazing,
i love it with coolant
just ordered Blue screw for this block and reservoir (Bitspower Upgrade kit)
all O-rings will be blue (pump, res and fittings)
update soon
