reserved for final pics and other stuff
01. (04/27/13) Original radiator mounting 1(scrapped)
02. (04/27/13) Initial designs
03. (04/28/13) Original radiator mounting 2
04. (04/29/13) Original radiator mounting 3
05. (04/30/13) Bitfenix Recon mounting solution (scrapped)
06. (05/04/13) Laser cut front panels
07. (05/05/13) Original radiator mounting 4
08. (05/08/13) Photos of work so far
09. (05/11/13) Photos and disassembly of original Mac
10. (05/14/13) Modding rear panel
11. (05/15/13) Modding front panel
12. (05/16/13) Modding rear panel 2
13. (05/18/13) Painting
14. (05/18/13) Photos of painted parts
15. (05/21/13) More laser cutting
16. (05/21/13) Photos of laser cut parts
17. (05/22/13) Painting
18. (05/22/13) Photos of painted parts
19. (05/30/13) More disassembly
20. (06/03/13) Angle grinding case
21. (06/04/13) Front panel mounted
22. (06/04/13) Front radiator mounting
23. (06/05/13) Cutting radiator mounts
24. (06/06/13) Bottom radiator mount
25. (06/06/13) Radiator photos
26. (06/07/13) Cable management holes
27. (06/07/13) Angle grinding
28. (06/08/13) Cable management and painting
29. (06/08/13) Removing the Apple logo
30. (06/10/13) Rear IO and painting side panels
31. (06/11/13) Painting side panels and handles
32. (06/12/13) Painting main body of the case
33. (06/13/13) Completed painting and first assembly
