1 - 20 of 277 Posts
ლ(╹ε╹ლ)
❚❚ Diginate.com ❚❚
❚❚ bequiet.com ❚❚
❚❚ FrozenQPCMods.com ❚❚
❚❚ Gigabyte.com ❚❚
❚❚ CableMod.com ❚❚
❚❚ Phanteks.com ❚❚
❚❚ ModMyMods.com ❚❚
du·al·i·ty
d(y)o͞oˈalədē/
noun
1.
the quality or condition of being dual.
"the novel's deep duality about human motive"
2.
an instance of opposition or contrast between two concepts or two aspects of something; a dualism.
"the photographs capitalize on the dualities of light and dark, stillness and movement"
Gaming
  • Intel i5 6600K - Delidded - 4.7 GHz @ 1.488v load
  • Gigabyte GA-Z170N-Gaming 5
  • G.Skill Ripjaws V 3200/16, 2*4GB
  • Gigabyte GTX 1070 G1 Gaming
  • ADATA SP900 m.2 256GB
  • OCZ Vector 128GB
HTPC
  • AMD 7870K
  • Gigabyte GA-F2A88XN-WIFI
  • Kingston HyperX Fury 1866/10, 2*8GB
  • Samsung 840 EVO 256GB
Common Hardware and water cooling
  • Antec EDG750 80+Gold Modular PSU with CableMod ModFlex custom cable set and combs
  • Phanteks Power Splitter V2
  • Custom Frozen-Q Apex mATX case
  • Frozen-Q resevoir
  • 4 * Be Quiet! Pure Wings 2 80mm
  • 2 * Phanteks PH-F140MP
  • 2 * Phanteks PH-F120MP
  • 2 * Phanteks PWM Hub
  • CableMod RGB 60cm LED
  • CableMod light blue sleeved SATA cables
  • Darkside White LED strips
  • Phanteks Extensions, 24-pin and 8-pin (red/black)
  • 2 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
  • Alphacool NexXxoS ST30 240mm
  • Alphacool NexXxoS ST30 280mm
  • Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M01
  • Alphacool VPP755 EisPumpe
  • Alphacool Eisdecke D5 Top - Plexi G1/4 - V.3
  • 4 * Alphacool G1/4 Passthrough Connector - Black
  • 24 * Alphacool Eiszapfen 3/8" ID x 5/8" OD Compression Fitting - Black
  • 10 * Alphacool Eiszapfen 45° Angled Rotatable Adapter Fitting - Black
  • 10 * Alphacool Eiszapfen 90° Angled Rotatable Adapter Fitting - Black
  • 4 * Phobya LEDready Twin 5mm Ultra-bright white 30cm - Black
  • 20 feet of Mayhems 3/8"-5/8" (10/16mm) Ultra Clear Tubing
  • 2 * Mayhems X1 UV Blue Concentrate 250ML
ლ(╹ε╹ლ)
Discussion Starter #2
Picture fiesta!
ლ(╹ε╹ლ)
Discussion Starter #4
Teaser.
Starting from the left. 3*Fractal Design Silent R2 140mm, 2* EK Furious Vardar FF4-140 and 3*EK Vardar F4-120.
ლ(╹ε╹ლ)
Discussion Starter #6
Originally Posted by KaffieneKing View Post
How are you making this case suitable for mounting 2 mobos?
Subbed!
The second motherboard will only have USB and HDMI as outputs used. The USB will be sent to a powered hub and the HDMI to my TV. I'll be mounting it inside. I don't physically have the case yet so exact placement has to be planned out when I get it. I do however have a good idea where to mount it
To physically mount it, I'll be modding the case to accept 4 more standoffs
Subbed!
I am also very interested to know this... subbed!
ლ(╹ε╹ლ)
Discussion Starter #9
I'll take better pictures of the painted fans when we can get sunshine again, nothing but heavy rain for the past few days and I need better light for decent pictures.
ლ(╹ε╹ლ)
Discussion Starter #11
So I installed the fans yesterday, I was a bit disapointed that I'm not able to mount 3x140mm fans in the front (it's not advertised as so, I just wanted it to be able to do that)
I might be able if I mount the fans inwards, but I need to mount them outwards so that I save as much space inside as I can for the ITX motherboard.
I didn't get time to take measurements to find where I want to mount what, but I have a good idea of how I'll be doing things.
I'm sure you'll not have any trouble cutting up the front to accommodate the fans anyway.
Either way, I am subscribed. Dual system builds are always cool to follow.
ლ(╹ε╹ლ)
Discussion Starter #13
The plan.
Place holder mATX board that will be replaced with my Z170A m5 board. They're the same width.
ლ(╹ε╹ლ)
Discussion Starter #14
With the great weather coming this weekend, I'll be able to get some real nice pictures for you guys on top of doing good progress.
I will be able to do most, but my 24-pin "y" will be another week or two to get from moddiy.
ლ(╹ε╹ლ)
Discussion Starter #15
I just realized with the ITX board orientation I want, I'll have to make a custom heatsink bracket for my Gammaxx 400 so the the airflow can go from front to back instead of top to bottom or the opposite.
Fun times ahead
ლ(╹ε╹ლ)
Discussion Starter #20
Since I like to tease, here it is running (only the ATX side until I get my 24-pin splitter and make my custom Gammaxx 400 bracket for the FM2+ board.
Major things left to do
  • Wire the ITX side
  • Wire the storage
  • Put the P400 reset switch as the power switch for the ITX system
  • Make an expansion slot with USB 3.0 and HDMI for the ITX system
  • Install the Swiftech PWM controller
  • Install filter for rear intake
  • Paint ATX side heatsinks and RAM
1 - 20 of 277 Posts
