41 - 60 of 64 Posts
· Tech Enthusiast
This is incredible, great work, just wow!!!
Discussion Starter · #45 ·
yeah i suspect this desk is something a lot of folks will be dreaming of owning once the complete piece is put out there :)
It is a dream of mine having built so many themed rigs over the years, I wanted something that i will never get tired of theme wise or be out of date and that I love (have a little collection of samurai swords).. and be timeless, hence the name timeless warriors.
Discussion Starter · #46 ·
So guys and gals it’s been a while since I updated, but the exciting news is we are getting very close to the end of the engraving side and onto the building side, ill just through these pics up for you to see how close we really are.
Oh I wonder what the lines to the right are for…………………………………..
So finally getting to the end of the amazing engraving and then onto the building part.​
· Broken
that is looking fab, just from the way the various bits reflect the room lighting I bet you could add different spotlights around the desk to give it a special life colouring as well (not sure how practical that would be for normal use but for a showcase event it would be pretty awe-inspiring to look at :) )
have to say every time I see these updates it does make me kinda jelly that I dont have those kinds of skills nor the patience required to do that sort of thing (my art ability is like a 3 yr old with really fat crayons) last time I tired to make something that wasn't created with straight lines on a draft table it didn't go very well ….
Discussion Starter · #49 ·
Back again with another update to the build, a long time coming was waiting and stalling it for some special items that a due in for the build (well 2 of them) but I thought I better put something out there to keep you all keen.
So engraving has finally finished at last, and boy is it truly an amazing piece of work do I call the build a build now or a piece of art, or artisan PC mod, god knows but I just can help staring at it. Time to put it back on top of the desk and get drilling some fill and drain ports in.
This is starting to take shape now, also one thing I decided to change was the toughened glass top, not only for practicality but also for the fact the std glass top was tinted and I did not want to dull the engraving down on the build.
I also added some extra overhang on the rear when sizing the replacement up, I wanted to ensure I had this to aid with my lighting plan for the rear of the desk and will aid in spreading light behind the monitors.
I also added a cut out to the rear of the desk were the monitor mount goes, my thought behind this is if for any reason I change something be it ram ect ect in the future, I wanted to be able to lift the glass off without going through the process of breaking down the monitors pulling the desk out and undoing the clamp on monitor mount as on the original glass it would of sat on top of it.
Finally I added a vanity panel to behind the legs and desk for cable tidying, which will enable me to only have three cables coming from the desk as the panel will allow for the power adaptor, router, network switch ect to be place in this. Which leaves only one power cable to wall socket and two network cables to the nas.
That’s all for now, as soon as the final two pieces turn up ill photograph them and get them up (although its four pieces in reality to give you a clue to what I am waiting for).
· The Physical Manifestation of Typos
Glad to see more progress being made on this build!
That artwork is gorgeous :drool:
Discussion Starter · #52 ·
Back again guys with another small update, still waiting on a few items to turn up to get into the actual build part, but started working out layout ect, so here are some pics.
Memory is ready to go into the motherboards, have replaced logos as well to match paint job I done them with, now to put them in these two puppies
Also some other parts turned up too, firstly the fans and cables needed to complete the build.
Yes that is 12 fans, a couple of splitters and 24 extensions for the fans…. A lot I agree, but I want to run the fan cables around the sides of the desk to keep them out of site as much as possible, a big thanks to noctua for sorting these out, much appreciated. Also the rads turned up and as I wanted crossflow, well thanks to the guys at Aquatuning they did.
Simple position of getting the fans on the radiators and putting them in and we can finally see what is starting to happen.
Let’s put the SSD’s in place and glass back on to get the look I am going for as a little test.
My samurai Armour SSD’s are now in place, now the one thing I had not taken into account when planning this was the length of Sata Data cables to reach round, even 90cm ones are not long enough, so I have had to outsource so small male to male data connectors and run over 2 cables each of the on show drives. And yes I do expect I will see a slight decrease on performance on 2 each on each side as they will be using these male to male adapters.
Good news is why I was doing this, two of the other 4 items I need to get stuck in turned up to, A huge massive thanks to my contact at Gigabyte for pulling these out of a magic hat, I did not expect them and thank you.
Now just waiting for the other 2 items, the waterblocks for these to turn up and I can finally start assembly, yes there are many minor and small things to do yet. But we are finally getting near the end.
Discussion Starter · #53 · (Edited)
Wow it’s been a while with any update so this will be a longer than normal post.
First off the GPU blocks have arrived (eureka) so let’s take a look at them.
Overall I like the design of these BP-VG2080RD-A2 blocks and they are also very heavy.
One thing I did like about this design is the use of the extra support for block on the back bracket
A nice small addition to help with the support of the heavy block, now shall we see how they look in place with the covers.
To be honest I was now at an small stall, waiting for a few more things to turn up so I thought I would figure out a cunning plan to hide the cables coming out of the PSU, despite them being mostly hidden by the top anyway. Also something to aid in my plan of having green gpu cables both sides to represent bamboo and tie in with the Japanese/samurai theme of it all.
So being me, I ordered to self-construct type Japanese houses and 2 watch towers for this sort of placement, thus hiding the psu output cables and guiding the green cables to the gpus, of course I will be painting them to match the colour schemes of each side.
Wanted to hide these cables specifically with the houses.
After doing this and despite knowing the houses won’t be hardly visible with top back on, I still wanted to spruce them up a bit… but first let me show you how this looks in
I know some people won’t like this idea, but I love it and it ties in with the theme, and wanted them to match the theme, translation of writing is dragon clan, then tiger clan on the matching sides to match the engraving. And know I won’t ever do stencils this small again and then hand paint them on (more on that later in post). The most shocking part of this stage is working out how to hide nearly 38 meters of cables and lighting in the desk :O.
On another note, I also decided to mod one of the bitspower hex tanks, the one for the black and gold side already had a black dragon on it (bitspower logo) I decided for the tiger side of the build I would try to make something not like bitspower logo, but very similar with tiger logo. I made this with vinyl.
It should match the general theme of one side of engraving being a tiger and samurai and one side being a dragon and samurai.
Now I did warn this was going to be a long post, so I’ll start by mentioning I am now lucky enough to be permanently sponsored now going forward by airbrushes.com on this a future builds (wish it would of arrived before I done the houses :p and hence my comment of I will not be hand painting ever again and can get back to airbrushing stuff again.
Hopefully I get the rest of the stuff soon to finish this massive project, on a plus note I don’t have to hand paint my planned stuff on the vanity cover on the bottom of the desk now this has arrived J
Mod notes to do list, fittings for gpu blocks to connect to each other to do, painting of vanity panel, tidying of the cables and extensions to go in and make acrylic covers for cable tidying inside the desk, fill and get air out of the loops, then sit and install windows on both machines and check for any conflicts or issues.. then book time to do photos and video of this epic piece.
Discussion Starter · #54 ·
So just another small little update, remember this.
This is the vanity panel I made to hide the power strip, switch ect under the desk, of course I decided to airbrush this too and tie it in with the inside.
I used a samurai quote in this which is used to describe two samurai warriors working as one.
Translation is “Different body, same mind.” Which for us westerners means Harmony of mind between two people. While I am here, I should also translate the writing on the houses for you, the lower roof on the house on black side says Dragon clan and on the white roof says Tiger clan. On the side of both the houses the translation is honor and truth.
Any way guys stay tuned as more of the small stuff is done before the big reveal
Discussion Starter · #57 ·
At last we got there in the end, it was a long process but I am so happy with how this mod/art piece came out, there were a lot of choices to make and I am amazed with the end result, it truly is a one off piece, some ups and downs during the build but got there in the end, enjoy the pics and the videos guys.
I Love it, but just when you think I already posted too many pictures, here are some different lighting modes for you of course with the rainbow unicorn too :p
And to finish it off, here are some videos for you to watch, first up is the video of how the engraving was done by my wife.
Second the Desk in normal mode
Last but not least Desk in unicorn mode ;)
One massive journey (and desk :p) but we got there in the end and I love my new art piece in my home, special thanks to the sponsors involved and also my wife for the engraving.
· Mining the DB
Absolutely spectacular build. Really is incredible. Great job. It looks fantastic.
41 - 60 of 64 Posts
