spray paint online?!
872 Views 14 Replies 7 Participants Last post by  Dallus
hi so im wondering where the best place to buy spray paint online is. i know most people will say just go to the store and ask if im under 18. yes i am under 18 but my parents go to home depot with me and buy it anyways. ive been to home depot/lowes/some auto store and i cant find the colors i really want
white acrylic enamel primer
white gloss acrylic enamel
white Alkyd Enamel plastic primer
purple gloss acrylic enamel
this is why i want to purchase online aside from the fact that if the company accepts paypal, i have alot of money on there. the store HAS to have all 4 of these paints
1 - 15 of 15 Posts
Originally Posted by Juggalo23451
try using google what I did when I was looking for duplicator mirage paint
i have been but i cant seem to find the right store. i keep getting like walmart and homedepot. they arent going to ship it tho
Do you know the brand of paint or just looking for those colors? I would see if duplicote has them if they do you can goto your local automotive store and they should be able to order it to the store.
well i wasnt going for a no name brand. krylon/dupli-color and such
i might use an automotive website. the paint is expensive but it should be high quality right? i can color match the white to the bmw 3series or infinit g37 as they are VERY white. purple will be a toss up. i guess i could grab it at home depot?(not the exact color i wanted tho)
You COULD use automotive paints, but be warned, it is VERY involved. They do create a great finish and are much more durable than rattle can paints.
You have to spray the paint for the best results so you'll need a compressor and the stuff to go with it as well as a spray gun. If you have these you're set.
As for the paint, you'll need a primer, color, reducer, clear and hardener. This site has a quick little explanation on how to paint using automotive paints. http://store.planetcolor.com/
You can usually buy automotive paints online, but just be careful cuz they are horrible for your lungs/brain more so than spray paints. So get a PAINT respirator and save some of your brain cells.
i was talking about actual spray paint cans with car paint in it. they color match it to any car which is pretty good because im only worried about messing up the white. the purple will be on the mesh which isnt hard to paint
Amazon?
Originally Posted by Core300
Amazon?
that was the first thing i tried but it was honestly so hard to find the right paint i just gave up(no im not ******ed)
I always thought buying paint online was a pain. It's confusing when it says a color in the description but the picture is of another color. I'm trying to think of where I ordered my Plasti Dip from now...
well i wouldnt order the purple online. just the primers and white(would would be automotive spray paint color matched to the bmw alpine white). ill have to deal with the closest purple that home depot has
Did you see DupliColor AutoSpray paints? That seems like the most cost effective auto paint.
1 - 15 of 15 Posts
