i run adaware or spybot (unsure of which, as i have both, and i don't want to run them again to find out which one) and it tells me it must reboot and run at startup to remove certain spyware. I do this, and when i select remove spyware (after rebooting) it displays "INCORRECT PARAMETERS" and locks up the system... ***....
If someone has another spyware removal tool i should try or anything that can help in the next half hour, please let me know.
BTW this problem is not with my comp... it's a customers... here are the specs
Win98
Intel P!!! 600MHz
192 megs of sdram
20gb HDD
DVD-ROM
56k modem
NVidia TNT2 128-bit 8MB graphics
Win98
Intel P!!! 600MHz
192 megs of sdram
20gb HDD
DVD-ROM
56k modem
