Originally Posted by broken pixel ![]() http://theovalich.wordpress.com/2008...ling/#comments |
- The squealing isn't necessarily caused by the vibration of high frequency coils, mostly because coils don't exist in most of today's high end inductors - there is just one strip of metal. In fact, that squealing could theoretically be caused by any component on the board, though inductors and capacitors are the biggest culprits. - The statement about "solid-state" capacitors isn't clear what you are referring to, that term doesnt exist for caps, however actually a large variety of caps (from MLCC's (small brown squares) to ALE's (cans)) have shown an aptitude for creating noise, some better, some worse. ... - Inductors have air gaps in their casing that allows for heat to escape (as well as from their leads). Covering your parts with nail polish could help the sound go away, it could also help shorten the life of your board dramatically. |
Originally Posted by gnolnats ![]() "......My EE degree trumps your ignorance." A little bit conceited, are we? I'm an EE also btw, and I'm sure there are several others in this forum. |
Originally Posted by shinji2k ![]() This is probably what pixel was trying to link to: http://theovalich.wordpress.com/2008...280-squealing/ There is a comment on that page that is very relevant to the topic: It's not just caps, the inductors are also the main culprit (and in my opinion moreso than the capacitors). As the anonymous poster rightfully imlpied, do this with caution. |
Daniela filled the inside of the capacitor/choke. We also removed all the factory-default thermal paste from the GPU and replace it with Gelid’s GX-1 compound. That reduced load temperature by 3 degrees, as we wanted to lower the thermal load of the PCB. |
