SSD arrives on Saturday :) Need some advice please
415 Views 9 Replies 7 Participants Last post by  br3nd064
I've just had confirmation that my 256GB GSkill Titan will arrive on Saturday morning
Feels like Christmas!
But I have a few questions for anyone who knows.
1. I've heard that defragging is no good for SSD's. Is that really the case?
2. Does anyone know if its necessary to set a page file when using an SSD? I would have thought it would be a good idea to have a page file considering how fast SSD's are, but I really have no idea
3. In Device Manager under the harddrive icon and policies tab there is an option for write caching, I have this checked with my current harddrive but want to know if its necessary for SSD's?
I guess I'm just going to have to wait for the drive to arrive to get the best idea and check myself but if anyone has an SSD that can advise I'd be grateful.
Cheers
1 - 10 of 10 Posts
Download this nifty utility. It should take care of nearly everything for you
http://www.ocztechnologyforum.com/fo...ad.php?t=49779
Thanks for the link
Some nice info being discussed there and that utility looks like it could be very handy
"Aoccdrnig to rscheearch at Cmabrugde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a tatol meses and you can sitll raed it wouthit a porbelm. This is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe."
Wow I raed taht wtihuot a porbelm.
No problem. I am getting my SSD hopefully friday or saturday too, so i guess we are taking the leap together
I found this:
Disable
Prefetch & Superfetch, Auto Defrag, Indexing, Write Caching, Short File Names, NTFS Timestamp. Disable ACHI in BIOS before Vista install
Vista Automatic Defrag
1. Click Start
2. Click Control Panel
3. Select the Control Panel Home
4. Click System and Maintenance
5. Under the Administrative Tools section at the bottom, click Defragment your hard drive
6. Click or unclick Run automatically (recommended) depending if you want this feature enabled or disabled.
7. Click OK
Remove Indexing
1. Go to, Start (blue marble) > Computer
2. Right click on your drive and select 'properties'
2. Uncheck 'index this drive for faster searching'
Disable Write Caching
1. From the Device Manager expand the disk drives category
2. Right click your drive. Select 'Properties' from the menu then click on the 'Policies' tab
3. Uncheck 'Enable write caching on the disk'
Disable Short File Names
The run command:
fsutil behavior set disable8dot3 1
Note that the Windows XP environment variables %TEMP% and %TMP% typically use short names. Program installations sometimes use these variables. If this change causes trouble and you need to restore the short name function, the command is; fsutil behavior set disable8dot3 0
Disable Timestamp for Last Access
The run command:
fsutil behavior set disablelastaccess 1
Note that some backup programs may need this information. If you wish to restore the timestamp, the command is; fsutil behavior set disablelastaccess 0
This is basically what the Tweak Utility does for you automatically
Defrags are useless on SSDs. I don't think you'll see much fragmented files on there, if any at all. The only reason they say it shortens their lifespan, is because their calculate SSD's lifespan by the amount of operations they do in a lifetime. If you were to defrag, that's a LOT of operations, therefore you'd be using up part of said operation for no reasons.
I would suggest running a traditional HDD in your machine along with your SSD. That is what I'm doing and it has been working great. I set my page file and browser cache on the HDD. It keeps the amount of writes on the disk to a minimum. Also whenever I download a file I do it onto the HDD. And don't defrag, the drive will only die quicker. You might also want to think about disabling superfetch and indexing in windows vista. Also check out the SSD section on OCZ forums. Not just the thread linked to above, lots of good info there.
1) Defragging doesn't do anything on a SSD since every file can be accessed in the same amount of time.
2) If it's necessary now, it'll still be necessary. You'll notice a difference if you use the page file a lot.
3) Not sure.
1 - 10 of 10 Posts
