1 - 20 of 32 Posts
From a discussion at Intel forums: http://communities.intel.com/thread/21717?tstart=0
If someone can read Chinese or Japanese, would you mind summarizing?
894.8TB written to a 40GB X25-V and it is still operational with some sector remapping. This is on 5 34nm 8GB NAND chips.
Intel rates their SSDs for 20GB write daily. However, most people write less than 8GB a day. This 40GB SSD is at 915865.6 GB written.
Like I keep saying, don't worry about write endurance too much.
UPDATE:
XS is repeating and expanding the experiment here: http://www.xtremesystems.org/forums/showthread.php?t=271063
MTBF is typically 1,000,000 hours on a SSD which is ~ 114 years, people worry a little too much about their ssd's - yes minimize writes, but it will typically out last most of us and our tortoise that we have as pets
Solid information as always - thanks!
Senior Member
Duckie, you always remove my doubt about many things:)
Yay, more reasons to love my Intel X25M G2 80GB SSD then
guarantee u, u will swap the ssd in 3-5 years anyway
whats this on cycle ive been seeing.
The Computer Guy
January 14, 2011 Status: Comprehensive written 782.9TB, approximately equal to 21,569 times, which were written to 21TB.
Thats a lot of write for a 40gb. SSD.
whoa, and i was a little scared at my 80GB G2 with 8.86TB written.. Lol
i actually worry more about the controller than nand writes. (That doesnt leave out you can do a little tweaking in your os and programs to make it more write friendly)
Discussion Starter · #14 ·
MTBF is NOT life expectency/service life!
MTBF is really not useful for consumers. It is useful for datacenters running hundreds/thousands of drives.
http://www.apc.com/prod_docs/results.cfm?DocType=White%20Paper&Query_Type=11&value=Ar
Mean Time Between Failure: Explanation and Standards
Discussion Starter · #15 ·
Have to say, this is quite interesting and makes all those little "tweaks" to decrease writes to the SSD seem a bit silly.
Totally unnecessary!
Translation
Intel X25-V measured durability
January 24, 2011 Editor: neeyuese type: Original Source: Comments: 0 Views:
March 30, 2010, please return to the block of Intel X25-V 40G Gen2 the SSD, the firmware in the Trim and Win7's support, the Durability Test.
Prepared to use their own procedures to override the 7X24 hours of torture overall purpose: to write until the hanging up.
A written document mode and B:
A class for continuing to write them:
10 ~ 100KB 80% (System thumbnails and the like)
100 ~ 500KB accounted for 10% (JPG images and the like)
5% 1 ~ 5MB (big picture, MP3 and the like)
5% 5 ~ 45MB (video clips and the like)
Where B is random write categories:
1 to 100 bytes of 100% (System log and the like)
March 30 brought home.
April 5 states:
Write 15.518TB overall capacity is approximately 426 times overall, including random file written 426GB.
CDI degree in E9 wear down from 100 90, (34nm of PE as 5000, there is also normal to remove 10%)
April 12 Status:
Write 37TB overall overall capacity is approximately 1030 times, which were written 1TB file.
Degree of CDI in the E9 wear down 79, E8 of the spare area down to 99 (down 1), re-mapping block to 2 (05)
April 24 Status:
Write 75TB overall capacity is approximately 2065 times, which were written to 2TB.
Degree of CDI in the E9 wear down 59, E8 of the spare area did not change. Re-mapping block to 3 (05)
May 7 Status:
Write the overall capacity of 112TB is approximately equal to 3084 times, which were written to 3TB.
CDI in the E9 wear a 39 degree fall. Re-mapping block to 6 (05)
May 18 Status:
Write 149TB overall capacity is approximately 4114 times, which were written to 4TB.
CDI fell in the 19 degrees of wear and tear E9.
May 30 Status:
Write 187.2TB overall capacity is approximately 5143 times, which were written to 5TB.
CDI in the degree of wear and tear into 1 E9.
June 10 Status:
Write 224TB overall capacity is approximately 6158 times, which were written to 6TB.
CDI in the value and the last, like, all remain unchanged.
June 22 Status:
Write 261TB overall capacity is approximately 7196 times, which were written to 7TB.
CDI is not loud noise in the value of variable, in addition to re-map into a block of 7 (05)
July 3 Status:
Write 298TB overall capacity is approximately 8212 times, which were written to 8TB.
CDI value addition in the re-mapping block into a 9 (05) did not change outside.
July 14 Status:
Write 337.1TB overall capacity is approximately 9264 times, which were written to 9TB.
No change in the value of CDI
July 26 Status:
Write 376TB overall capacity is approximately 10,338 times, which were written to 10TB.
No change in the value of CDI.
August 5 states:
Write 410TB overall capacity is approximately 11,274 times, which were written to 11TB.
CDI, or no change in the value.
August 18 Status:
Write 447.2TB overall capacity is approximately 12,228 times, which were written to 12TB.
CDI in the re-mapping block (05) suddenly increased to 12.
September 1 Status:
Comprehensive written 485TB, approximately equal to 13,334 times the capacity, which were written to 13 TB.
CDI in the re-mapping block (05) to 16.
September 14 Status:
Comprehensive written 523TB, approximately equal to 14,371 times the capacity, which were written to 14TB.
CDI in the re-mapping block (05) to 1C - 28 个.
September 28 Status:
Comprehensive written 559TB, approximately equal to 15,419 times the capacity, which were written to 15TB.
CDI in the re-mapping block 05 increased to 1E - 30 个.
October 12 Status:
Comprehensive written 597TB, approximately equal to 16,458 times the capacity, which were written to 16TB.
CDI in the re-mapping block 05 to 27 - 39.
October 27 Status:
Comprehensive written 633TB, approximately equal to 17,467 times the capacity, which were written to 17TB.
CDI in the re-mapping block 05 increased to 2A - 42 个.
November 16 Status:
Comprehensive written 671TB, approximately equal to 18,492 times, which were written to 18TB.
CDI in the re-mapping block 05 to 30 - 48.
December 7 Status:
Comprehensive written 708TB, approximately equal to 19,517 times, which were written to 19TB.
CDI in the re-mapping block 05 increased to 4C - 76 个. E8 of the spare area finally became 98 from 99 a.
December 28 Status:
Comprehensive written 745TB, approximately equal to 20,538 times, which were written to 20TB.
CDI in the re-mapping block 05 4F -79 were increased.
CDI in the re-mapping of 05 increased to 5D - 93 个.
Currently still suffering, nearly 7,000 hours to this start, pause every 12 hours during the period under optimized under the Toolbox.
Look at these figures, you tangled Durability Who's? Bought back from the March 30 beginning not to shut down in writing, writing for nearly 300 days a seemingly unassailable still.
General Depot of the SSD are mostly broken firmware, rather than grinding grain damage, return the factory re-opened card (production) will be able to continue with the next.
Generally bad firmware locked in a sudden power-down, lock damage map, firmware, bad brush and so on. Manufacturers out of the regular firmware have to do extensive testing to ensure compatibility (hundreds to thousands of hours of testing led to the release of the firmware extension severe), even that ran into Intel, Micron's firmware door, slip through the net is indeed visible Many (of the world's compatible with the strange), but as such a fundamental sandforce in every 2 months, update the firmware of the product is good in the end get to the bottom also means ah.
1 - 20 of 32 Posts
