SSD for Macbook Pro
1247 Views 24 Replies 8 Participants Last post by  Skink910
Hey, Im looking at upgrading my drive in my Macbook Pro. Currently I have the 128gb SSD that came with the Macbook. I am having issues with space and need to make the jump to a 256gb SSD. I have a 1TB external that I uuse for data and nonsense like that. I have been looking at the Samsung 830 and 840 series SSDs, and now I go to actually make a purchase and I see the Samsung EVO series. I'm wondering what my best option is and why? Im also wondering of anyone has ever installed an SSD into a Macbook Pro and if its difficult or if I should just pay geek squad $50 and let them do it. Thanks for the help!
Also what do I need to know about getting more memory for my Macbook Pro? Can I get any laptop memory or does it need to be Mac specific?
1 - 20 of 25 Posts
ram and hard drive upgrades are easy. Depending which ram your macbook uses you can get it here:
http://www.crucial.com/store/listmodule/DDR3/list.html
Heres some info to replace it and find which you need:
http://support.apple.com/kb/HT1270
its not mac specific but you will need a specific type of laptop ram
The SSD though samsung 840 is well recommended not sure about the evo. But samsung is a good ssd brand either way im sure you'd be happy.
I helped my dad replace the video card in his 2008 imac. They have only gotten smaller and more cramped and I would assume the laptops are the exact same. That being said I personally would just drop the 50 bucks on geek squad to install it. I broke the logic board on my dad's mac... fixed by resoldering I think a capacitor that I had knocked off of it. Not something I want to relive.
most hard drives and ram sticks are as simple as unscrewing a cover on the bottom and taking them out/putting them in. Video cards are a whole nother ball game. Even if you have to take it apart its still just a computer crammed into a box. Much harder to take apart but they make lots of guides that make it go smoothly
Yeah I've looked at some guides for the RAM and that looks very simple. I haven't seen much on the hard drive. Also I need to clone the drive. Apple says you have to buy a USB enclosure in order to be able to access the old drive with the new one installed. I've heard of people saying that the migration didn't go well with theirs, what exactly does this mean? I'm fairly new to this.
an enclosure is basically a case that you plug the ssd into that has a usb adapter so you can plug it into your computer. The key is getting one that doesnt suck. You buy a 5 dollar special and your probably going to have some issues.
its usually better to just do that and transfer over what you need after you reinstall your OS fresh and start over.
So if I understand this correctly, would I be able to use mt old SSD as an external SSD for storage afterwards? Also Ive never had to reinstall OSX, do I just go to the app store and download it or how do I get my OS back to the laptop? And are there any enclosures that you would recommend?
yup you can use it afterwards as external storage.
http://www.ebay.com/itm/Rosewill-RDEE-12002-2-5-USB-3-0-SSD-HDD-Aluminum-Screwless-External-Enclosure-/300949971552?pt=US_Drive_Enclosures_Docks&hash=item4612042260
something like that would work fine, cheap but not a horrid brand so it should be a decent enclosure.
I am not familiar with mac so im not sure about OSX. It says they now offer it for 19.99 on the app store. But I honestly have no idea how to install osx. Should be lots of instructions out there heres the one directly from mac:
http://support.apple.com/kb/PH11273
obviously your drive will already be erased but id imagine from that same menu you can just use a blank drive and press install osx. I am not sure there id check around see what information you can find first. From what i read here you may need to find a OSX disc of some sort:
https://discussions.apple.com/thread/4697858?start=0&tstart=0
Thank you so much for your help! One last question (at least for now)
Should I just use the old drive as an external and literally just copy over what I need to the new drive or should I use a cloning program and clone my old one and copy that on to the new one. I keep my drive very clean and I'm not replacing it for bad data or anything like that I just need more space. And if I do the copy route will I be able to copy over licensed products like photoshop and other products that ive purchased?
If you do the copy route you probably wont be able to copy programs youve purched but im sure you can just re-download them through the store so long as your on the same apple account that owns them.
Cloning will definitely be easier and save you all the trouble of having to re-install osx. Its just usually nicer to start from scratch, gets rid of any possible mistakes you may have made along the way
. But if your confident your comp is clean and good to go then cloning it will work fine and you wont have to install anything
Wow... I did a RAM upgrade less than a year ago for $40 - same capacity and frequency. Can't really fault you for that, but the RAM market sucks right now.
The SSD is a good one. I'm a fan of mine. Is this a SATA II or SATA III model laptop? If it's SATA III, then don't get that. Get THIS. It's basically an 840 but with a pseudo-SLC write buffer for faster writes. Basically, there are three kinds of SSDs: SLC is the enterprise variety nowadays. Each cell only holds one bit. MLC holds two and is the standard for consumer drives. TLC, like the 804 and 840 EVO, hold three bits per cell. As you add more bits per cell, the read speeds stay the same, but write speeds will begin to drop. The EVO emulates an SLC drive by allocating, in potentially your case, 9 GB of storage space into a 3 GB buffer. If your laptop is SATA II, then either the 840 or EVO would be good. I'm not entirely sure, but Samsung RAPID might be available for OS X. That is a program allowing 25%, 1 GB max, of your RAM to be used as an additional write cache. If it is, then you can potentially bypass SATA II speeds for writes under 1 GB, and will then be copied to the drive itself when idle. It's available for Windows for sure, but I don't know about Macs, sorry.
The enclosure: no idea. Just find one that's cheap and reliable, really.
When you transfer data over, cloning is the easiest option. Reinstalling the OS is also an option, but I'm too lazy to do that when I upgrade. Too much work downloading stuff and reconfiguring settings. And yeah - licensed programs will work. When you clone, it makes an EXACT image of the drive. All install keys are there, cookies are leftover from your browser of choice, those prawns you've been meaning to delete are still floating around somewhere...
And finally, you sure can use the old drive for external storage, but I'd rather have the old one for a scratch disk on my desktop. Most media goes on an HDD, but a large paging file and any current projects go on the SSD for ease of access, for example. That said, it wouldn't make a bad external drive at all. Flash memory is less prone to break when dropped, and when you're on the go, that's a very real possibility. The only issue right now is $/GB for that sort of application.
I checked the website. Only Win supported.
I'm looking for the same thing and will be getting the 840 evo 250gb if that means much to you. I can vouch for the 840 pro, I have that in my desktop and it loads win8 in under 10sec. I have a 2011 macbook pro base model 13" for school. Load times are pissing me off. Looking forward to the speed. OP let me know what you finally decide and how it goes!
dan.
840 Pro is a awesome drive, but the performance of Samsung 840 Evo is also really good, but price is much better.
Thank you guys so much for all the help! I am very new to the whole computer world, but learning quickly, my ultimate goal is to build myself an NLE Rig that will also be used for gaming in about a year when I graduate from college. Im not sure if my laptop is SATA II or SATA III, is there somewhere I can look that up? I have a Late 2011 Macbook Pro 15". As for the drive you guys have been EXTERMELY helpful and I thank you guys again for all the help
I will for sure keep this thread updated as I go through the upgrading process. Right now I am waiting on a package from my Dad that will hopefully have the right screwdrivers that I need to do the work. Once I have the tools I will be making the purchases and doing the upgrades. I am very excited to breathe new life into my Macbook
I only confirmed my laptop was SATA II when I did a benchmark with my shiny new SSD.
Even then boot times were half or a third the time compared to a 5400 RPM HDD, and I'm pretty sure I'm limited slightly by POST times and significantly by CPU power. I can't link because I'm on my phone but it is probable that it is SATA III based on a thread on the Apple forums. Good luck, have fun, and remember that you're about to jump into a money-pit and never come out. But you have a Mac, so you know that.
2013: Haswell
2012: Ivy Bridge
2011: Sandy Bridge
Sandy Bridge is when Intel added native SATA III ports to their chipsets so I'm guessing your MacBook probably has SATA III.
Originally Posted by rui-no-onna View Post
2013: Haswell
2012: Ivy Bridge
2011: Sandy Bridge
Awesome thanks!
So I think I'll switch to the EVO instead of the Pro based on what CyncialUnicorn said:
So I decided to go ahead and make the purchase now and if the right tools are not in the package I found a pretty fair priced set I can get at Home Depot.
Here is what I ordered:
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147248
Enclosure: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182276
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231342
Okay so I am waiting on my package so I can finally get to work! As I was thinking about everything I came up with a question.
When I install the new RAM will the macbook automatically recognize my new RAM and update, or do I need to do something in order for the laptop to know that I put new RAM in?
Also, is there any reason why it would be better for me to install the new drive first or the RAM first? Basically what order should I install them or does it not matter?
1 - 20 of 25 Posts
