My friend has finished building his Sandy Bridge build. Relevant hardware:
CPU: i7-2600K
Mobo: ASUS Maximus IV Extreme
GPU: Gigabyte GTX 580
SSD: Crucial 256GB SATA III
We inserted the Windows 7 Ultimate (64-bit) CD into the CD drive. The screen goes to the windows installation screen, but among the drives, the SSD is not detected. Additionally, even when we remove the drive, it seems that the computer is still looking for the CD drive, even thought there's nothing in there. We can't enter even the EFI BIOS after pressing "delete" when prompted. After we press delete first, it then proceeds to do the drive searching, loads the "press delete" screen again, but then promptly goes to a black screen with one underscore flashing about three lines down the screen. What's going on? He's worried the SSD is dead, which I doubt but it could be. Just for additional info, the CD drive and SSD are plugged into the SATA III ports using the Marvell controller. Any ideas what's going on and how to solve it?
EDIT: The motherboard gives the code AE, which, in the manual, says "Legacy Boot event". Dunno if that's significant or not but any info is good info in this situation I guess.
CPU: i7-2600K
