I'm not sure but for boards that do not have sata 6 onboard is it capable to run an SSD boot through an addon sata 6? Since you can't boot OS through pci ssd's and afaik the sata 6 adapters connect to the pci slots so does that mean if you buy a sata 6 SSD means you can't boot your OS from it? Need a quick confirm so I don't end up buying a classified right now and not be able to boot OS from sata 6.
