stability!
304 Views 4 Replies 3 Participants Last post by  Prelithe
I use Prime95 to test stability on my system. After 4 test I always get the same result. one of the instance (CPU1) always cras after exactly 7hrs 16 minute. The other instance still running... Does that mean that one of the core is stable and the other isn't??? Or both are unstable or 7 hour is enought to say that it is stable... Exept of Prime05 I have no proble at all....
1 - 5 of 5 Posts
One core isn't stable. Try increasing your voltage one notch if your temps can handle it and try again.
I'm actualy tring that right now... I have Prime95 running at home with 1.5v, I,ll see tonight the results. But at 1,5v my CPU temps doesn't even break th e50 celcius with the stock cooler
With 1.5v Prime95 failed on 1 core after only 22 minutes. But ran 6 hour on the other core with no errors...??? strange... I think that maybe I've been unlucky and get a crappy chip that can't handle a 200mhz overclock
. it's been a mouth that i'm posting all my problem and tried all imaginable setting but nothings work you guy help me a lot but now I think it's time to accept that I won't get this thing work over 2.4ghz....
hmm Chim3ra said, inc the voltage to 1.55 hopefully would stabilize it. Athough, it could be the memory (most unlikely but hey worth a shot). Try running it on a divider (333mhz) and see how prime goes
1 - 5 of 5 Posts
