1 - 13 of 13 Posts
I might have tacos tonite
It's hard to tell what to fix if we don't know what you did exactally. Did you just run a program, or edit the registry, or give your modem an energy drink to make it go faster.. ?
Discussion Starter #7
riiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiight,now i was trying to make my laptop have internet from my desktop and got it but something came up and had to go somewhere with the laptop brought it back hooked it up and the network was gone ,i tryed to fix (note:this is where the word optimize came in lol
)it and faild and was like screw it and fired up sc and notiesed its not connectin,i reinstalled the gam thinking it would solve the problem ,well i guess u know what happend if u see me asking for help
my guess would be windows firewall has re enabled itself on your network adapter. if you go to properties on my network places, then properties on your local area connection, under the advanced tab you can take the check mark out.
You might want to check out any other firewalls you have also.
1 - 13 of 13 Posts
