1 - 4 of 4 Posts
Guys I have a problem: the PC (w7 64 bit) does not want to know to start, it loads the screen with the windows logo then turn off your monitor and restart (a few times instead of the monitor is off, I saw a BSOD). Restore tool startup (suggested by the same system in some reboots) failed to solve. I have no previous restore points saved. I tried to start it in Safe Mode but I did it only once, other attempts end up with a reboot after loading the files. That one time I was able to provisionally read something minidumb with bluscreenviewer and I remember that reported "Caused by driver: Raspptp.sys" and underneath was "Raspptp.sys + c0d5" Unfortunately, all the other items I do not remember.
Do you know what is derived and above all how to solve?
· Premium Member
I would suggest inserting your Windows 7 installation disk and selecting the "repair my computer" option. Open a command line and run chkdsk /f to see if you have disk errors. Let us know if it finds any.
Alternatively, you can always just backup your data and reinstall Windows....
repair dont fix it
I have deactivated the automatic restart and I see the bsod: the code say
*** Stop: 0x0000001E (0xFFFFFFFFC0000005, 0xFFFFF800044E123F, 0x0000000000000000, 0xFFFFFFFFFFFFFFFF)
· Premium Member
Microsoft says the following:
•There is insufficient disk space on the drive on which you installed Windows.
•There is an outdated or incompatible third-party driver (or drivers) installed on your computer -- for example a faulty video driver.
•There are system BIOS incompatibilities
The first one is not likely,
The second one is very possible. Did you add any new hardware lately?
Update your BIOS to the latest version and see if that helps.
1 - 4 of 4 Posts
