Steam - Do I have a Cross Fire Issue
2265 Views 12 Replies 8 Participants Last post by  Avenged-512
Guys
Looking at my System info on Steam it only shows recognition of one GPU. However when I review CCC and ZGPU it shows both my cards in Xfire.
Is the system info in Steam wrong or do I have an issue? At the moment I only play MW2 and soon to be LD42 on Steam but I'd rather get this sorted and make full use of my Rig.
Any ideas?
1 - 13 of 13 Posts
I trust cpu-z and CCC waaaaaaaay more than Steam..
Im with the above poster. I never have used steam to check my hardware (much less didnt know that i could....)
May have to check to see what mine says.
I'd be interested to hear the result.
It only recognizes one of my 9800GX2's.
And by that I mean one GPU out of the four.
AFAIK, Steam doesn't detect multiple-GPU configurations, just like 3dmark doesn't acknowledge more than one card (except in the score and framerates).
I finally checked my steam; and it displays only one GPU.
-I have the same problem with my two xfx radeon 5770 xxx in crossfireX, the problem is not that Steam doesn't recognize the second GPU, it is that the game is only working with one GPU. When I look to the Ati Catalyst Control Center after 3 hours of playing Metro 2033 at high settings my first GPU is at 70ºc and the second is at 0ºc, I have enabled the CrossfireX with the 10.10 version of Catalyst Control Center, please I would like a solution.
Steam system information has no effect on how the games play.
Well, so can you tell me how to enable CrossFireX for Metro 2033.
-Well so...Can you tell me why Metro 2033 doesn't use the second GPU, I have installed many times the drivers, and I have CrossFireX enabled on Catalyst Control Center 10.10 version.
Thank you. There's no problem at all, everything is solved. I only re-installed the profiles for ATI. Thanks.
1 - 13 of 13 Posts
