1 - 20 of 48 Posts
Everytime I try to log into steam it stops responding!<br><br>
Ive uninstalled and reinstalled using the steaminstall.exe from the site and it don't work.<br><br>
Ive Deleted temp files and updated all the stuff, dont work<br><br>
Ive made a new directory and im tranfering the SteamApps folder over.<br><br>
Any other ideas?
When you uninstalled did you clean the registry afterwards? You can use the one in Ccleaner which works great for me. <a href="http://www.ccleaner.com/" target="_blank">http://www.ccleaner.com/</a><br><br>
Also you might want to check and see if antiviruses/spyware/firewalls arent getting in the way. Those messed up my steam but allowing it fixed the problem.
Discussion Starter #4
Now it says you internet connection is not there!!! Shoot me now!<br><br>
I have run McAfee and it didn't find anything and either did Ad-aware <img alt="" class="inlineimg" src="/images/smilies/mad.gif" style="border:0px solid;" title="Mad"><br><br>
I cant take it anymore, I need to try my Icemat <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><br><br>
No I dont use Peergardian anymore - Steam was working this morning and I havent doen anything else <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
just settle down, I've had these problems many times best thing to do is to wait it out, it's usually a sign of steam going through new updates. Do a couple of reboots, registry cleans, spyware cleaners, etc. etc. And keep trying, it'll eventually work you just gotta wait. I know that it says "Not Responding" in task manager, but it really is. Just you wait, it'll be working in no time.
Just sleep mad, everything will be fine in the morning....
Discussion Starter #8
<div>Originally Posted by <strong>Niko-Time</strong></div>
<div style="font-style:italic;">Just sleep mad, everything will be fine in the morning....</div>
</td>
</tr></table></div>
Sleep? What is this "sleep" you speak off?
Lol, this happend to me once.<br><br>
Fine in the morning the in the afternoon it made the computer dead slow/freeze, i thought to myself not this! Then as i was about to quit it the computer went back to normal and has not done it again since<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #11
I dont want to wait though - I want to test the Icemat NOW NOW NOW <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">
Discussion Starter #13
<div>Originally Posted by <strong>cokker</strong></div>
<div style="font-style:italic;">All good things come to those who wait, NOW WAIT!!!! LmAo!</div>
</td>
</tr></table></div>
This isnt a beer advert - this is me were talking about! <img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2">
Discussion Starter #15
<tr>
<div>
</div>
<div style="font-style:italic">Did i say beer? lol.</div>
</td>
</tr>
</table>
</div>"Good things come to those who wait" - Guinness Quote<br />
<br />
lol
Here is exactly what I did to mine.<br />
- Restart computer. - Try again<br />
- If that doesn't work, go steampowered.com, download and install Steam on another dir.<br />
- Log in by creating new account, let it update all platform and stuff.<br />
- When done (you're in Steam main Windows), quit Steam, get in the new dir, copy steam.dll and steam.exe over to the old dir, should overwrite the old ones.<br />
- Restart - Try again.
Discussion Starter #17
<tr>
<div>
Originally Posted by <strong>shajbot</strong>
</div>
<div style="font-style:italic">Here is exactly what I did to mine.<br />
- Restart - Try again.</div>
</td>
</tr>
</table>
</div>I tried that last night - No Luck still not working!<br />
<br />
When I try to run steam.exe in the new dir it wont even let me log in - opens steam.exe and then stops responding and uses 100% CPU <img src="/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" />
Administrator
Sometimes to fix this issue. Go into the STEAM folder for the STEAM CLIENT and delete the File called Clientregistry.blob. This will re-register some details of your system and you will need to re-imput your details. <br />
<br />
Also if that doesnt work uninstall the steam client and remove left over registry entries using Registry mechanic as this will probably fix it .
Discussion Starter #19
<tr>
<div>
Originally Posted by <strong>ENTERPRISE1701</strong>
</div>
<div style="font-style:italic">Sometimes to fix this issue. Go into the STEAM folder for the STEAM CLIENT and delete the File called Clientregistry.blob. This will re-register some details of your system and you will need to re-imput your details. <br />
<br />
Also if that doesnt work uninstall the steam client and remove left over registry entries using Registry mechanic as this will probably fix it .</div>
</td>
</tr>
</table>
</div>Ive done that also <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /><br />
<br />
I tried everything last night!
1 - 20 of 48 Posts
