1 - 4 of 4 Posts
steelseries QcK Mass Mouse Pad
Description:
Composed of high quality cloth and a rubber base this supersized mouse pad is ideal for every gamer preferring cloth surfaces. It features extremely heavy thickness which results in a very unique feeling. Also the thickness provides the ability to level of the tabletop it's used on.
Details:
DetailValue
BindingPersonal Computers
BrandSteelSeries
EAN5052217067272
FeatureSmooth cloth surface
Steady rubber base
Extra thick
Great value for the money
FormatCD-ROM
LabelSteelSeries
ManufacturerSteelSeries
Model63010
MPN63010
PublisherSteelSeries
SKUK7-W7B8-41WD
StudioSteelSeries
TitleSteelSeries QcK mass Gaming Mouse Pad - Black
UPC813810010455
Warranty1 year
ColorBlack
CatalogNumberList - CatalogNumberListElementDH63010
63010
Q916-63010
Item Height2.8 inches
Item Length13.7 inches
Item Width4 inches
NumberOfItems1
Package Height3.5 inches
Package Length13.9 inches
Package Weight0.75 pounds
Package Width4 inches
PackageQuantity1
PartNumber63010
ProductGroupPersonal Computer
ProductTypeNameABIS_ELECTRONICS
UPCList - UPCListElement813810010455
962327250400
Item Weight0.65 pounds
HardwarePlatformpc
OperatingSystemN/A
Exactly what I needed.
review by zemco999
At first I went out and bought a Razer mat. It disappointed me as it was extremely thin. I saw this one in store at Walmart for $10 and was psyched! It saved me $20 and was much better quality. The space is plentiful for FPS games and is larger than the average mouse-pad. The top feels a little rougher than silk, but is extremely fine. I have never experienced a skip while using my mouse, and I can roll it up to travel. It is very cheap for a gaming mouse pad, but VERY cost efficient. Do not be dissuaded by this price, as you will regret it! The logo is non-intrusive, and I love the look of it. It is durable, and easily washable (my cousin ate goldfish from it one day thinking it was a placemat). The black color makes sure you will always be able to use it with every color except white. The only con is that it the mat will slide if you accidentally drag you palm against it. Otherwise... It is amazing. Buy it. Don't think about it. Buy it.
ProsCons
Cheap, Awesome, Large, Black, Non-intrusive Logo, DurableSometimes Slips
Ratings
Overall4
review by zemco999
Yes agree i also happened to have purchased a razer vespula for £35 which was ruined within a month of normal use; got this QcK for £18 and not regretted purchasing it. been almost two months and still brand new.
1 - 4 of 4 Posts
