1 - 3 of 3 Posts
The back of my case, where the Slot brackets get screwed in, the one that also has one 120mm fan opening, and 4 40 mm fan opening, has ist first PCI bracket broken, so i cannot screw a PCI Card if it is single Slot, and inserted in the first Motherboard PCI Slot.
This part gets attached to the Motherboard sliding tray with 4 screws, and, since it can be taken out by unscrewing These 4 screws, i thought to myself, it could also be replaced.
The Thing is, i havent seen such part in the CaseLabs accesoies list one could order.
This is the part, where one choses by case ordering, if one wants the backpanel to be with 4x40 mm fan openings, or without. I#m sure it is understandable of which part i am talking about.
I can get only the one highlighted in green, right ?
To bad, you dont do the one with 4 40 mm Slot.
Well, i just ordered the part in green. I guess i just have to do without the fans. I#m sure i can do a mod to install them if i want to.
1 - 3 of 3 Posts
