1 - 4 of 4 Posts
I was thinking.. and I thought that instead of getting another 512MB of the same I have now. To just get a 2x512MB of the Corsair Value Series.
The only thing is that, I want to know. If I should have 4 sticks of the exact same memory, or would it matter if I went with 2 sticks of the same memory and then another model on the other DIMM port.
A matched pair gig is plenty enough and right now anymore is really wasted and a performance increase is not even worth it. Unless you are running servers a gig is plenty.
1 - 4 of 4 Posts
