1 - 5 of 5 Posts
hey all,
a few weeks ago my computer started crashing without reason.
while gaming, while idling, while [email protected], just random times.
so i started testing everything a few days ago, and i found out that 1 of my GEIL Black Dragon 1600Mhz sticks was busted.
yesterday i got them replaced, so now i got Corsair Vengeance 1866Mhz ram.
works awesome, but i keep getting the random BSOD's
now i found a site with all the BSOD code's in a nice list so you can see what's wrong, but now i got an error that got me confused.
just now i got this:
STOP Error 0x00000024: NTFS_FILE_SYSTEM
STOP error 0x24 means a problem occurred in ntfs.sys, the driver file that allows the system to read and write to NTFS drives. STOP code 0x00000024 may also display "NTFS_FILE_SYSTEM" on the same STOP message.
so...is my Windows installation borked of is there something else wrong?
· Premium Member
a 0x0..24 BSOD is CPU instability
check your OC
check your OC
This site says otherwise
it says : STOP error 0x24 means a problem occurred in ntfs.sys, the driver file that allows the system to read and write to NTFS drives.
and the cpu oc is rock-solid.
tested it with multiple programs like Prime95, LinX, OCCT, all for a minimum of 12 hours.
ow and i've been using this oc for almost 4 months now
1 - 5 of 5 Posts
