Still work on SMP
451 Views 12 Replies 5 Participants Last post by  H3||scr3am
Ok, so I've figured out the smp, but I get the message that I need to accept the license agreement. I have no clue what to do for this one. I know I have to write -license, but what else to I add to the end? It goes so quickly that I can't read it.
1 - 13 of 13 Posts
I hope this does work for everyone. It's my first time using SkyDrive.
well, as you can see, it doesn't seem to work. I'll try to type it all in instead.
Note: Please read the license agreement (fah6.exe -license). Further note of this software requires that you have read and accepted this agreement.
4 cores detected
Unable to connect to 'Adam-PC:8676'
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Adam-PC on port 8676, No connnection could be made because the target machine actively refused it. (errno 10061)
[20:36:46] Error running mpiexec. Please check your configuration and re-run install.bat if necessary
where do I get that? I don't think I installed with install.bat...
I've looked everywhere on folding site, and can't find the install.bat
anyone know where it is?
There's a reason this guide exists.
Thanks very much. It explained a lot to me. Right now I'm doing 1% every 80 seconds or so... it's a lot faster than it was.
I am not getting it to work with FaHmon though. Every time I add it on there, it shows up with a red icon. It doesn't work with fahspy (atleast the gpu clients don't work on there...) Any more I could try?
Originally Posted by gibsonnova74
Did you follow this guide for fahmon? http://www.overclock.net/overclock-n...vista-smp.html
Ok, so thanks everyone for the help... but I have a question in the guide that you posted. It says "*The SMP client console requires a password on your system" I don't remember doing anything with a password with the SMP client. Am I supposed to have the client that works well with the computer or one with folding stuff.
Normally to get the windows SMP it requires a windows passowrd on the computer that you then type into the SMP when running the install.bat. As it appears to be working you must have done it.
I think if its crunching along at 80seconds/% and he hasn't run install.bat, or typed in his windows password anywhere, the thing is hes only running a regular client...
You need to run the install.bat, and feed it your windows account password, let it run, it will say if you see this twice mpich is working... then rerun the smp client with the smp flag, after deleting your work folder, and queue.dat files... also why not post some screenshots for us
they help us help you. one of FahMon would be nice, we can also read your fahlog to try and help you out
1 - 13 of 13 Posts
