1 - 20 of 28 Posts
My 3200 is running very hot - sometimes 54 idle and 63 load - its only on stock cooling - no AS5. Is it supposed to be this hot? and how can i decrease it. The case side is off - i dont have any fans yet (this friday). Any suggestions?
reseat it, that sounds too hot. Also you put on the right amount of thermal paste on it? Finally is this your first amd setup, cuz I made a mistake and didnt turn the little switch thing on the side of the heatsink which seats it properly. Did you flip it?
Yes the side off will help
u answered your own question... lol apply as5! then the case fans will help some more... read through this faq to help you place the extra fans for max airflow...
maybe find a small house fan and place it blowing into the side of the case with the side panel off for a temp setup
http://www.overclock.net/other-cooli...-1-inside.html
do you mean there is no thermal paste on it? or just stock paste no AS5? My 3700 only runs around 32C idle and 42C load on stock cooling. Also do you have any fans in your case at all? My other comp. has a 3000+ proc. and there is no case fan in the back which makes it run about 10C hotter than normal
i didnt get any paste - there was this gunk on the heat sink though
yours is running 10c hotter and no case fans, his is running 20c hotter!!!!
that has to be a seating problem. Or at the very least too much, not enough thermal paste
it wasnt so much of gunk but it looked like a black patch of the plaster (band aid) glue
well i think u should go get some tonight or asap, and local pc shop will have atleast some cheap stuff... but go for the AS5
that is the original paste that you shoudnt touch. They did it for you prior to buying the cpu (im guessing new retail huh)? You sure its seated right?
Put your computer on its side and see what temps you get. if it drops like 3/4 degrees than its a seating problem
ill reseat it and have a nose about to see whats wrong - post back in about 20 mins
Did you remove the clear protective film before assembly?
The case fans will help a lot, you need air flow in the case... I bet your system temps are up too!
Discussion Starter · #12 ·
i did exactly as the instructions said - to the word - i did take the protective film off - im not that dozy, lol
Ive reseated it and the load temp is now 55 - 10 degrees less - the thermal paste hasnt cured yet too
Discussion Starter · #13 ·
btw - my idea of load is folding for a good couple minutes - let the temperature stabalise - how long does thermal paste take to cure? couple days or longer?
usually around a week... and calling FAH your load temps may not actually be the full load, run the prime95 stress test that uses large FFT's, that will max out your cpu...
The stock stuff is silicon based and has no real seting time, Also as the paste is preapplied it my be sitting around for a while while in storage the paste may lose some of its conductivity from oxidising.
Discussion Starter · #17 ·
Been running Prime95 for a good 10 minutes now. It seems to hover around the 57 region.
hahaaaa i knew i was right. The duke has a rep of 1598 and didnt say if he agreed or not! But from what he was saying was that it was the fault of the case and that wasnt right!!!
thanks you, i am a guinness
Discussion Starter · #19 ·
dude, calm down, its still running hot but ill sort that out once ive gotten my graphics card - for the mo ill clock it at 2000mhz - 200fsb x 10 @ 1.4v
Discussion Starter · #20 ·
Ive managed to drop my temp by another few degrees - the BIOS was limiting the HSF according to the core temp. Ive disabled it and the fan runs at 3,000rpm permanently now, with no extra noise either
Im running at the mid 40's average use now. I think ive got this sorted - i might try mild overclocking - maybe to 2.2ghz and see how it holds up.
1 - 20 of 28 Posts
