1 - 3 of 3 Posts
Hi Guys<br />
<br />
I finally recieved a E6300 to replace my 805D, man it's a lot faster.<br />
<br />
It scored 30 Seconds in Super PI 1M test at stock. But with my 805D @ 3.6GHZ that scored 37secs.<br />
<br />
Anyways my temps are really good, 25 idle @ stock using the Freezer pro with AS5.<br />
<br />
I checked with CPU Z and it saying 6x multiplier for somereason were it should be 7x.<br />
<br />
This is at stock btw.<br />
<br />
It's going from 7 to 6 quite often is there a option I can turn off in the bios to fix this.<br />
<br />
Gigabyte 945P S3.<br />
<br />
Cheers<br><a href="http://assets.overclock.net.s3.amazonaws.com/6/60/607e6ed7_vbattach33443.jpeg"><img src="http://www.overclock.net/image/id/616890/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/a/a4/a4a929c6_vbattach33444.jpeg"><img src="http://www.overclock.net/image/id/616889/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/e/e8/e8b7bb46_vbattach33445.jpeg"><img src="http://www.overclock.net/image/id/616888/width/525/height/525/flags/LL"></a>
Either an old version of CPU-Z, or you can raise your multi in BIOS.
EIST it's a function in BIOS that drops the multi, I think. I turned it off and I was good to go. Enjoy your chip, don't forget to use Intel's Thermal Analysis Tool when you're checking temps (or core temp), and keep it below 60.<br />
<br />
I got my Arctic Freezer Pro today and am amazed by it.<br />
<br />
Have fun.<br />
<br />
Jimmy
1 - 3 of 3 Posts
