1 - 6 of 6 Posts
Hello,
Does anyone know the basic differences between windows storage server and windows datacenter??
I could be wrong, but if I recall correctly storage server is more for file storage, similar to like a SAN operating system. And the Windows Datacenter is more for massive database applications like SQL server and other database driven apps.
Just checked, and yes thats right..
Storage Server
Simplify your storage needs with Windows Storage Server 2003 R2. Whether your need is for file sharing, storage consolidation, backup and recovery, or replication, Windows Storage Server 2003 R2 creates a platform for network attached storage. Based on Windows Server 2003 R2, Windows Storage Server 2003 R2 is branch ready and offers superior price-to-performance ratio, enhanced manageability, and increased productivity.
http://www.microsoft.com/windowsserv...3/default.mspx
Datacenter
Designed for the highest levels of virtualization, scalability, and reliability, Windows Server 2003 R2 Datacenter Edition, supports large-scale virtualization and mission-critical solutions for databases, enterprise resource planning software, high volume real-time transaction processing and server consolidation. Windows Server 2003 R2 Datacenter Edition is available in x86/32-bit and x64/64-bit versions through Volume Licensing agreements from Microsoft resellers and account managers, in addition to original equipment manufacturer (OEM) partners. Windows Server 2003 Datacenter Edition is also available in IA64/64-bit through OEMs only.
http://www.microsoft.com/windowsserv...atacenter.mspx
A regular Windows OS is limited on the number of connections it can accept (I want to say 16, but I'm not sure). So unless you have only a very limited number of clients that you want connecting, a server-based OS is required.
· Premium Member
That's not true at all. It was implemented to prevent viruses and trojans spreading around a network (imagine ~6000 computers) in SP2, but you can get different patches which will fix it.
Not to my knowledge. I was under the impression that it is intentionally throttled to prevent a cheap workstation license from serving as a file and print server.
1 - 6 of 6 Posts
