1 - 6 of 6 Posts
ok guys<br />
i have a DD TDX rite now and i m thinking of buying a Storm CPU block. But i really wanna know whats the temp difference btw Storm and TDX. is it like 1-2 C or more than that. is it really worth the money??<br />
<br />
thnx guys plz leave some reason why you think one is better than the other
Found this, which in a nutshell says the temps difference between a tdx and a storm or appogie is not worth the price <a href="http://www.overclock.net/water-cooling/69894-tdx-vs-rbx.html" target="_blank">http://www.overclock.net/water-cooli...dx-vs-rbx.html</a> <br />
<br />
My <img src="/images/smilies/2cents.gif" border="0" alt="" title="2cents" class="inlineimg" /> with my appogie i get 32-34c while folding single core loaded and 36-38c both cores loaded with my [email protected] with 1.53vcore with a 23-25c ambient
Reactions: hanwinting
I agree^^ If you want to squeeze the last 10mhz out of your cpu than the storm might help but I think its far from worth it.
Discussion Starter #4
thnx guys rep for u 2 <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
SNERP!!!
The storm is worth it if you take your IHS off your CPU, but with a stock CPU you are fine with any of those.
Snerp hit it on the head.
1 - 6 of 6 Posts
