1 - 6 of 6 Posts
check this out... here is the pic.. anyone got a idea? i just went to set auto all on my cpu cuz i oced it to 3.6 but i am still noobie with overclocking. that sux.. hope anyone can suggest abt it
Discussion Starter #2
i meant... i oced it before and i set it to normal. (no oc)
Super Moderator
Simple, Cool N Quiet is turned on. Disable Cool N Quiet, and you should be fine. If not, make sure your multiplier is set to default (those screenshots show it at 10.5x, it should be 15.5x if I remember right).
Reactions: Zerogamer22
Discussion Starter #4
allright. be back right. i'm gonna go to bios now
Discussion Starter #5
i disabled Cool N Quiet now. i see 3.2 ghz....whew i checked the cpuz... i'm using my h50. shall i overclock it to 3.6 ghz? i have 750 watts.. might planning to get 5850..
Super Moderator
Go for it
. Just make sure you test stability with each step. Check around the forum for an overclocking guide if you aren't sure where to start at.
With an H50, 3.8-4.0GHz should be fairly easy with your CPU
. Good luck.
1 - 6 of 6 Posts
