1 - 2 of 2 Posts
Ok installed my audigy 2 today disabled on bored sound and insatlled drivers all went ok.
I also brought creative inspire 6700 6.1 speaker system only using the center and 2 front speakers and sub at the mo because of space, now the center and sub work great and so does the right front speaker but i have no sound out of the left side speaker whats wrong? When i plug the left side into the rear socket i get sound its a bit weird. Anyone help?
I'm not sure if your card has one, but if it does, use the mixing/settings program that came with it. You should be able to run speaker tests to see where the problem is. You might have a blown speaker. Switch the right and left plugs to see if that does anything.
1 - 2 of 2 Posts
