Have you attempted to re-seat the block?
Is the pump functioning intermittently? |
Did you thoroughly clean and inspect all the components prior to assembly: I seem to recall a person having issues with performance, that upon closer inspection, discovered a piece of packing popcorn in the pump that was inhibiting flow. |
Can you post pics of your loop? |
The reason I ask is because I've had a couple of Asus mobo's that would do the same thing yours is doing, they had faulty v-reg's on them. |
I generally take off and straight-edge any stock sinks I leave on my mobo to make sure they are making good contact, a lot of the time the sinks wont be making contact on the components very well. |
